gen 3 knock sensors in a gen 4
Hi guys Im putting a gen 3 block in my 2010 truck.Problem is the gen 3 knock sensors are 1 wire and the gen 4 are 2 wire. Im thinking if I can ground out one wire and connect the other one to the knock sensor or if someone makes an adaptor harness. I reallly dont want to turn of the knock sensors any help is greatly appreciated
http://www.racetronix.biz/itemdesc.a...1-KSRH&eq=&Tp=
Note however that you will need to change the knock sensor 'type' with a software editor ala EfiLive etc..
