Compression ratio question???
Pretty much the same as a stock LS2.
Depends on the cam specs. Stay conservative with the cam specs and you should be fine.
What compression would have with a LQ9 with 243's heads?
Would have problems with flat pistons and LS3 heads?, I had observed some LS3 pistons with valves relief?
Ls3's have flat top pistons, L99's have the -2cc valve reliefs due to VVT.
Here's a link to help out. I believe 243's are 64cc's
http://mobile.dudamobile.com/site/wa...ng.com%2F#2707
