Every engine builder should have one of these
AlignIt is a LS Timing Cover & Rear Main Cover Alignment Tool and Seal Installer!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Timing and Rear Main AlignIt Kit Save 10% Only $58.41
http://www.saccitycorvette.com/Timin...nmenttool.html
Here is a video that shows how simple it is to use.
Installation with Oil Pan off.
Here is a Video the shows installation of Rear Main cover and seal with the Oil Pan on.
AlignIt Rear Main Tool. Only $37.95
Front & Rear AlignIt Kit. Save 10% Only $58.41
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Hi TNSS,
There is a shipping charge. I think its $6.50
Thank you,
Christian
Thank you,
Christian
__________________
We have the AlignIt Rear Main Seal Tool ready to go! We have a instructional video of it here and on our website. :Cheers:
Thanks
Christian
Thanks
Christian
__________________
Thank you TNSS for your business, we really appreciate it!
__________________
These sure make cover and seal installation simple!
__________________
We were waiting for someone to laugh with us!
__________________
