Anyone modify a Kooks TD?
They said add resonators or a second set of mufflers, however since they do not have a jig for this system they can be of no help getting them installed. Unfortunately there is no shop around here with the ability to do custom mandrel work.
That sucks. I don't have any access to a mandrel, but I'm hoping I can just get rid of the little kinks in the I pipes and run straight 3 inch smooth tubes. I think they are 3.5 inch OD but I'm going to call SW to be sure. I still haven't gotten a chance to work on the car. I repairing respiratory equipment for a living + this allergy season = a lot of work.
The X pipe is wider than I expected. It could work if I cut the Kooks system before the X, weld the mufflers going straight back, then slip fit the x pipe into the mufflers. That MIGHT work and go into the Kooks over axle pipes.
I cannot put into words how disappointed I am with the Kooks True Duals. I spent an absurd amount of money on a full Kooks setup, and when I wasnt satisfied they acted like its my fault. I feel like Ive been robbed by a cop.
I was going to use the kooks mufflers along with this setup. Unfortunately the magnaflow muffler necks down to a single 3" or less in the center of the muffler for maybe 3-4 inches. Also I haven't been able to find a j bend in 3" that is as tight a radius as the picture.
I just put the smooth tubes in line before the kooks mufflers, and I must say that Im very impressed. The tone is deeper, and the volume dropped about 8 dB standing next to the car, and a whopping 16 dB drop at 20 ft. Thats from a muffler that has a 3 inch inlet/outlet and only a 3.5 inch outside diameter. STAINLESS WORKS FTW!
Now I have to cut out everything from just before the X pipe on the Kooks system to right before the over axle pipes to get these things where they need to be.
I just put this system on my car with a 408 in it and I agree with the rest of you is much too loud to drive in town and not attract unwanted attention (i.e. cops). Does anyone have any feedback on how much quieter I can make the system if I put the kooks high flow cats on instead of just the straight pipes? I hate to spend the money to buy the catted intermediate pipes if the difference isn't that noticeable.
#33
Out of curiosity, what kind of system are you guys coming from? I've mentioned this in PM's on this issue and never really considered this system "unbearable". Subjective, I realize as there are louder and worse sounding systems, but am curious....
Personally, having run a LM1 and Corsa, I consider the catted version of the Kooks comparable in noise, but smoother.
#34
I think that's a valid point, I am coming from a stock 5.7, long tubes, ORY with a cat-back flowmaster to a 408 medium cam kooks long tubes and off road kooks TD. I think it's just going to take some time for it to sound "normal".
#35
I'm scratching my head about this thread.... I just ordered the exhaust from Maryland speed on the 16th. A course it's go take a while to sound "normal" cause let's face it. a y pipe go sound totally different from a X pipe setup. I want a different sounding exhaust. I don't see myself investing money in another exhaust system. I ordered the kooks without the cats. I hope it sounds better than slp borla corsa etc.....
#36
#37
I switched to 1-7/8 Kooks with the TD. I picked up a good bit of torque (30+ ft lbs) But Im willing to lose a few to make it more driveable. My car is louder than my friends 383 with his cutouts open.
#39
