Truck oil pan cooler inlet/outlet question
Hi,doing LQ4 6.0 build and have a question as to which port on bottom rear of pan can I use for turbo oil supply. In the truck it had manifold there with two pipes going forward to oil cooler. I have block off plate with two 1/8" pipe thread holes. I want to use supply for turbo oil feed and block other off. Which one is supply(front or rear)??? Thanks
