Alternator wiring
Alternator wiring
Will try to keep this brief... Have a LS3 crate motor w/ GM harness & ecm. Alternator is a 140a AD 244 w/ 4 prongs + 1 bat. Harness has 1 pink wire to alt (assume this is for ecm? does this provide remote sensing? should I run it to the Master cut off switch?) What are the other 3 prongs for?
Appreciate any enlightenment ya'll can provide.
btw car is a 67 elcamino, remote battery, master cut off switch which must kill entire electrical system (NHRA)
Check this out Geoff -- info in the thread and some links. Not conclusive -- but the best info I was able to get. https://ls1tech.com/forums/conversio...conundrum.html
