Best way to get to 500hp with an L92?
I'm pulling the motor from the donor truck soon and considering having the long block overhauled at a local machine shop. If I do I'm thinking of swapping out the cam for something higher performance. The motor will likely go into the M37 project we're starting but MAY go into a C3/C4 vette.
Here is my question. Whats the most cost effective way to 500hp without a ton of machining? I've read online that Com cams has a cam kit that will do it but I'm wondering what specifically people will recommend and how close to a simple drop in is the installation?
Motor will go in front of a 6 speed either 6l80e or manual. Wouldn't mind a bit of a lumpy idle but the motor is gonna be a driver for the street so nothing thats hard to run.
L-92 vvt ok
Hi, I would install a LS-3 intake, have the cam "reground" by Crower (my spec), fit larger fuel injectors, yellow springs, longer pushrods, VVT limiters (mine).
A re-tune would be required, stock EMS ?
Lance
Lance
Which injectors?
Approximately how much would the above cost less the intake? I'm in Canada to it might be better to have the cams reground here as trans border shipping is brutal.
Canada Shipping
OK, my wife's parents, parents, built (owned) the Canadian National RR.
I KNOW where the MOST beautiful women are from, Canada.
I would fit my Denso 450cc (42.lbs), they idle better than OEM.
So the costs, I ship USPS, stated value is how "duty" is TAXED.
I would like to call, just PM your Phone #.
Lance
Lance
