Fast 102 mid length runner results!!!
Old 02-25-2017, 05:28 PM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
Default Fast 102 mid length runner results!!!
This is a graph from my Engine Dyno results.
Build details are in Dyno results section
Titled "396" DLRE,MMS,.....727 FWHP"
The Mid Length Runners, peaked 7100-7300 RPM, and carried
another 500 RPM only dropping 8 HP. The standard
long runners would have peaked 6600-6800 RPM and fallen of
a cliff 500 RPM later.
Had the opportunity to Speak with Richard Holdener
(King of the Dyno Testers) he was testing on the other
Dyno @ WesTech.
Mid Length Runners need Cam & Head Flow to Peak HP @ 7000-7500 RPM,
shifting 300-500 past peak HP.
Short Runners need 8000+ RPM HP peak.
Old 03-15-2017, 05:23 PM
Thought I would post some ideas for a killer street/strip
416". MMS LS3s, LLSR 249*/257* 114*+3* .670"/.640"
11.5-12.00:1 Comp, FAST LSXR, long runners for street
590-600 Lb Ft, shift @ ~6500, Mid Length for Track
725+ FWHP, shift @ 7500RPM+ with Vacuum Pump.
Good for Upper, Maybe Mid 9s full weight F Body,
with good suspension.
Old 03-15-2017, 08:28 PM
KW Baraka's Avatar
Originally Posted by NAVYBLUE210
.....The Mid Length Runners, peaked 7100-7300 RPM, and carried another 500 RPM only dropping 8 HP.
The standard long runners would have peaked 6600-6800 RPM and fallen of a cliff 500 RPM later.....
Just want to clarify......."no dyno runs with the standard, long runners?"
KW
Old 03-15-2017, 08:53 PM
big hammer's Avatar
These mid runners are going to leave the old guys behind with their long runners and 3/4 cams
Old 03-15-2017, 08:58 PM
KW, That is correct long runners were not tested. The mid-length
runners were ported by Tony with the intake. I did not have the
Long runners ported as I did not want to pay to port those as
I do not intend to run them. At best I would have peaked 560
Lb ft perhaps 565 @ ~5000 RPM, but with earlier peak HP and
Much quicker roll over.
A longer stroke with more cam would show more significant
Differences with runner swaps from 6000-8000 RPM.
Old 03-15-2017, 09:22 PM
North*power's Avatar
Default If only Cathedral port!!
Man, I really wish FAST would go and make mid length runners for the cathedral heads. I have MMS 235's on a 416 with all the supporting mods and I have been debating switching over to a Hi-Ram for more top end. Has anyone cut the factory runners and recreated a bellmouth on them!?
Old 03-15-2017, 09:33 PM
big hammer's Avatar
Just get an MSD. They're more similar to a mid runner fast
Old 03-15-2017, 10:23 PM
Originally Posted by north*power
man, i really wish fast would go and make mid length runners for the cathedral heads. I have mms 235's on a 416 with all the supporting mods and i have been debating switching over to a hi-ram for more top end. Has anyone cut the factory runners and recreated a bellmouth on them!?
MMS msd + llsr !!
Old 03-15-2017, 10:26 PM
Was not able to capitalize MSD or LLSR ??
Old 03-15-2017, 10:49 PM
big hammer's Avatar
I think the forum is set so that if you write in all capitals it changes it automatically
big hammer's Avatar
Im writing this in all capitals
big hammer's Avatar
Yupp.
Old 03-16-2017, 09:27 PM
KW Baraka's Avatar
KW, That is correct long runners were not tested............
Thanks!
KW
Old 03-24-2017, 08:44 PM
64post's Avatar
Informative thread. Someone will probably manufacture different length (shorter) runners for the cathedrals before long.
Old 03-24-2017, 09:26 PM
sillysspeed's Avatar
Hope your right!... Either that or people will continue to switch to the MSD
Old 03-25-2017, 12:33 PM
gnx7's Avatar
Not likely "before long"
Old 03-26-2017, 03:05 PM
64post's Avatar
Why not? There's enough requests for it then it will happen. I hear and read people asking about it. Sooner than later, it gets done IMO. It's only polymer plastic, should be easy enough. Licensing may be a factor.
Old 04-08-2017, 08:40 PM
BmanZ06's Avatar
Damn nice numbers!
Old 04-08-2017, 10:01 PM
Thank You BmanZ06,
i see you have an LSX Block for your Build also.
What are your plans?
Old 04-10-2017, 03:26 PM
Emailed FAST again today. The still have no plans of making the mid length for cathedral. I'll probably switch to MSD or modify my existing runners in the next few months.
Quick Reply: Fast 102 mid length runner results!!!
