1 7/8 header worth it for l92 heads?
Originally Posted by Pwebbz28
I wouldnt think you would gain anything if the exhaust port opening is still smaller than or equal to 1 3/4. After you get a bigger port you would most definately need 1 7/8.
It really depends, I'm running the 1 7/8s stepped to 2in with a 3.5in collector and I gained some powereven after I added the cats to get some back presure from the 1 7/8s. I'm at stock cubes, and I could feel the difference when I went to the 1 7/8s from the 1 3/4s. and the dyno verified that, I think in has more to do with how aggressive your setup is aka how much air you are flowing
