PCV setup for custom LS7 install - LS1TECH
Thread Tools Search this Thread
Old 04-10-2007, 01:17 PM   #1
Needs to finish car
Chris442's Avatar
Default PCV setup for custom LS7 install
I am putting an LS7 into a '68 Camaro, and I am not sure how to run the PCV lines mostly due to my aftermarket oil tank. The stock setup on the 'vette is very similar to the LS2. There is no PCV valve, and the intake sucks air out of the valley cover. Supply air for the opposite side of the system is drawn from the intake tube and then into the valve covers. However, unlike the LS2 the supply air is routed through the dry sump tank. There are in and out fittings on the top of the stock oil tank.
On my car, I have a Peterson 2 gal. tank that has one -12 AN breather fitting at the top of the tank. Due the scavenge pump pulling at least some air out of the pan, the tank has to breath somewhere. Obviously, it would be easiest to breath it to atmosphere. Since I am going to run a MAF, if I want to keep a PCV system, I can't do that. Also, I would like to run a catch can somewhere.
Here is what I was thinking: Catch can between the valley cover and the intake (the normal spot). Draw supply air from the intake tube in front of the TB. Put a tee on the fitting on the dry sump tank. Then route to each valve cover. This is basically the same as the stock setup. I am concerned that the tee fitting might not breath the tank properly. The problem I can foresee is that it might push oil into the intake tube at WOT. The last thing I want is to get oil into the intake.
Anybody have any thoughts?
Chris442 is offline   Reply With Quote
Old 04-10-2007, 03:00 PM   #2
See5 is offline   Reply With Quote
Old 04-15-2007, 09:33 PM   #3
Moderator
John B's Avatar
You can see my Peterson tank with their breather tank and how I used a catch can coming off the valley cover:
John B is offline   Reply With Quote
Old 04-16-2007, 01:48 PM   #4
Needs to finish car
Chris442's Avatar
John -- Does the breather can only breathe the oil tank, and the rest of the PCV function like an LS2 with a catch can?
Does your setup skew the l-trims at all?
Old 04-17-2007, 10:17 PM   #5
Moderator
John B's Avatar
I tap fresh air from in front of the TB and route this to the valve covers via a "T". I then route the valley cover air through the catch can to the TB.
Nope
Related Topics
Thread Thread Starter Forum Replies Last Post
PCV Catch Can Routing Question "Forged LS7 with LS3 Topend" breze84 Generation IV External Engine 2 06-24-2016 05:07 AM
Plumbing clean/dirty air for speed density tuning efnfast Generation IV External Engine 5 04-27-2016 02:47 PM
Another PCV Discussion/question jaybracer1 Generation III Internal Engine 1 01-08-2016 10:41 AM
Crankcase evacuation system and ITB's? lstvr Generation III External Engine 0 05-12-2015 06:08 AM
APS PCV system... problems? SStolen Forced Induction 0 07-13-2008 03:32 AM
Tags
1968, 68, breather, bzdel, camaro, custom, dry, install, john, ls1tech, ls7, oil, peterson, sump, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
