ARP bolt part number for LS2 block
I did a search, did not find my answer.
I am bolting my 243 casting LS6 heads to a 402 block, what is the ARP part number for the head bolts?
TIA
TIA
just in case someone accidentally leads you in the wrong direction, they should have a different PN than the old LS1 if you didn't already know, they were revised and now the bolts that were insanely long are no longer there, they are now short.
Thanks for the reply,,, I knew that there was an issue with getting the right length ARP bolts for the LS2 block,,, and I read that it is the block type that determines the correct bolt length and therefore the correct ARP part number.
LS1TECH & Trucks Sponsor
234-4316 is the 12 point stud kit for the '04+ cars.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
