UPDATED- L92/L76/LS3 Engine Into 99-02 F-Body - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 12-26-2008, 08:30 AM   #21
General Jack's Avatar
Quote:
Originally Posted by idumb View Post
What is VVT cam phaser or Active Fuel Management?
Sorry i am a new member learning about f-bodies. i dont own one but my boyfriend does. its his hobby so i figured i would learn more about it. he has a 1995 camaro z28 and is putting an ls3 in it.
So the ls3 doesnt have a VVT cam phaser or AFM... Is it bad that those motors dont?
Basically it allowsfor cylinder shutdown at low loads to improve fuel efficiency. IMO, its best to avoid for hot rodding because we're all about making more power, not saving gas! Just more to deal with during the conversion if you have a VVT engine.
General Jack is offline   Reply With Quote
Old 12-26-2008, 09:27 AM   #22
Oh ok. That makes sense. Thank you!
idumb is offline   Reply With Quote
Old 12-27-2008, 01:14 PM   #23
i was reading a little and saw that an ls3 and a l92 are kinda the same? Or is it they just have kinda the same headers? Is it true that the ls3 also is from a truck? cuz thats what i was told but then i was reading and kept seeing that its from c6 vette... And whats an ls7?
Old 01-05-2009, 02:54 PM   #24
Quote:
Originally Posted by drain89 View Post
They've released it for sale and added it to their site. I added a link to it above in the info.
yea it came in a few days later, it looked beautiful but sadly, i was scamed by 89formulaws6, the motor had a bad crank but i wasnt informed of this, so when my engine builder checked it out he pulled the crank and put the right one in, so i never got a chance to use the conversion box
t/a98 is offline   Reply With Quote
Old 01-06-2009, 06:56 PM   #25
speedy55's Avatar
we have a 07 escalade motor we want to do a carb conversion on using the MSD ignition controller. What are my options as far as the VVT is concerned?
speedy55 is offline   Reply With Quote
Old 01-06-2009, 08:30 PM   #26
drain89's Avatar
Quote:
Remove it. You'll have to remove the displacement on demand also if it has it.
See the list above to see what you need. Disregard the EFI parts and sensors, they don't apply.
Hope you got a deal on it. With changing the cam, cam gear, timing cover, and possibly the lifters and lifter trays you'll have alot more than if you got a used LS2 or 6.0 LQ4/LQ9 truck motor.
drain89 is offline   Reply With Quote
Old 01-20-2009, 10:13 AM   #27
what about oil presser sensor.l sorry if you said i just didn't see it
Big Bird WS6 is offline   Reply With Quote
Old 01-21-2009, 05:53 PM   #28
Not trying to jack the thread, but on a similar note, would it be possible to get a Vortec 6.0 (LQ9???) and use that computer and harness for a swap into a '94 LT1 Firebird? I know the appropriate external parts would still need to be changed to the car versions, but is it reasonable??? I know that anything can be done with time, money, and knowledge...
Slowmo_Bird94 is offline   Reply With Quote
Old 01-23-2009, 01:57 PM   #29
^ ^ ^ a 6.0L is a gen III if that helps you any
Old 01-23-2009, 01:59 PM   #30
Vtard
Quote:
same as ls1
dlove is offline   Reply With Quote
Old 01-25-2009, 11:36 AM   #31
The 6.0 looks JUST like an LS motor, but with an iron block. Still a gen 3???
Old 01-25-2009, 08:37 PM   #32
GrannySShifting's Avatar
yes it is
GrannySShifting is offline   Reply With Quote
Old 01-28-2009, 03:09 PM   #33
Ok, Thanks for the help.
Old 01-30-2009, 12:31 AM   #34
Is it possible to have a 224-236 size cam with AFM?
ArrestMeRed99Z28 is offline   Reply With Quote
Old 02-24-2009, 08:58 PM   #35
fbam's Avatar
Can the valley cover, cam sprocket, and timing cover come from and ls1?
fbam is offline   Reply With Quote
Old 02-25-2009, 03:20 PM   #36
Quote:
Valley pan = NO
knock sensors moved
Cam sprocket = NO
cam sensor trigger
Timing cover = NO
Cam sensor pickup
Lurk is offline   Reply With Quote
Old 02-25-2009, 03:22 PM   #37
I had some questions of my own
I see suggested to replace rod bolts and all the bearings? Any reason such as know issues or just a 'Might as well?'
Oil pump, what if the L92 doesn't have DOD. Then the pump is a standard unit, correct?
Old 02-25-2009, 03:56 PM   #38
fbam's Avatar
Quote:
Originally Posted by Lurk View Post
Valley pan = NO
knock sensors moved
Cam sprocket = NO
cam sensor trigger
Timing cover = NO
Cam sensor pickup
So all I need to do is install an ls2 cam sprocket, timing cover, and valley pan and I'm good? In regards to these particular items that is.
Old 03-04-2009, 09:11 AM   #39
Essentially, yes. But you need to make sure it is the correct LS2 timing cover, because there are several, and not all of them may work. I Also think you need the correct hardware and timing chain snubber as well. Lingenfelter sells a kit for this.
Brad Hutchcraft is offline   Reply With Quote
Old 03-04-2009, 09:32 AM   #40
Haans249's Avatar
This is some good information
Quote:
Originally Posted by nycblazer View Post
LS3 Bare Block Completion Kit part numbers and prices
Part # Qty Part Description
12599296 1 Valley Cover w/ bolts, seals, gasket and pcv baffle
GM PART # 12599296
OUR PRICE: $71.90
12599298 1 PCV Tube
GM PART # 12599298
OUR PRICE: $5.47
12600325 1 Front Cover w/ Cam Sensor, Seal, Bolts & Gasket
GM PART # 12600325
OUR PRICE: $68.49
12602548 1 Coolant Crossover Pipe
GM PART # 12602548
OUR PRICE: $21.25
12602540 2 Coolant Caps
GM PART # 12602540
OUR PRICE: $4.95 x 2 = $9.90
11588714 4 Coolant Pipe/Cap Bolts
GM PART # 11588714
OUR PRICE: $2.64 x 4 = $10.56
12615666 1 Rear Crannkshaft Seal Housing
GM PART # 12615666
OUR PRICE: $39.68
12574293 1 Rear Crankshaft Seal Housing Gasket
GM PART # 12574293
OUR PRICE: $14.86
11515758 12 Rear Crankshaft Seal Housing Bolts
GM PART # 11515758
OUR PRICE: $0.45 x 12 = $5.40
89060436 1 Rear Crankshaft Seal
GM PART # 89060436
OUR PRICE: $13.51
12573460 1 Oil Galley Rear Plug w/ Seal
GM PART # 12573460
OUR PRICE: $4.39
11588949 2 Oil Plug Side
GM PART # 11588949
OUR PRICE: $4.71 x 2 = $9.42
9427693 4 Water Drain Plug Frt
GM PART # 9427693
1453658 2 Transmission Dowel
GM PART # 1453658
OUR PRICE: $2.57 x 2 = $5.14
11609289 1 Water Drain Plug - Hex
GM PART # 11609289
OUR PRICE: $7.59
12589016 1 Camshaft Retainer Plate
GM PART # 12589016
OUR PRICE: $13.63
11561455 4 Camshaft Retainer Plate Bolt
GM PART # 11561455
OUR PRICE: $2.16 x 4 = $8.64
12570125 2 Knock sensor
GM PART # 12570125
OUR PRICE: $8.08 x 2 = $16.16
12585546 1 Crankshaft Position Sensor
GM PART # 12585546
OUR PRICE: $28.75
11515756 1 Crankshaft Position Sensor Bolt
GM PART # 11515756
OUR PRICE: $0.45
12591689 1 Cam Gear
GM PART # 12591689
OUR PRICE: $15.26
11561283 1 Cam Gear Bolt
GM PART # 11561283
OUR PRICE: $2.08
12556582 1 Crank Gear
GM PART # 12556582
OUR PRICE: $19.76
12586482 1 Timing Chain
GM PART # 12586482
OUR PRICE: $32.05
12588670 1 Timing Chain Dampener/Slide w/Bolts
GM PART # 12588670
OUR PRICE: $11.55
12601402 1 Balancer Balancer - 6.0 liter - 6.0 liter
06-08 $119.80 $71.02
12557840 1 Balancer Bolt
GM PART # 12557840
OUR PRICE: $3.20
12595365 4 Valve Lifter Guides
GM PART # 12595365
OUR PRICE: $5.56 x 4 = $22.24
12551163 4 Valve Lifter Guides Bolts
GM PART # 12551163
OUR PRICE: $1.53 x 4 = $6.12
total $549.03
just thought some one might this this as reference.
Haans249 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Converting L92 accessories and intake manifold to LS3, how to, part numbers etc. nakedpants Generation IV External Engine 0 09-05-2016 01:47 PM
LS2 conversion info inside Alex L. Generation III Internal Engine 36 11-24-2015 01:05 PM
Oil pump "too big"? OverkillGTP Generation IV Internal Engine 11 07-30-2015 10:43 PM
L76 information jameso1985 Generation IV Internal Engine 0 02-24-2010 11:52 PM
Any Interest in a L92 based 427 longblock? Jantzer98SS Northwest Members 10 03-20-2008 09:34 PM
Tags
02, 60, camshaft, carburetor, chevy, conversion, cover, lifter, liter, location, ls1, ls2, ls3, pan, position, sensor, valley
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
