UPDATED- L92/L76/LS3 Engine Into 99-02 F-Body
Old 11-01-2010, 09:45 PM
  #101
WicketMike's Avatar
Does anybody know what else I would need to put a LS3 into my 1998 ?
Should i also change the PCM ?
Old 11-02-2010, 11:12 AM
  #102
ss.slp.ls1's Avatar
You can use your stock LS1 harness and PCM. You have to do one of two things:
1) Pull the crank reluctor and swap it for a 24x tooth reluctor wheel and install a 1x cam sprocket.
2) Ensure that you have a 4x cam sprocket and pick yourself up a 58x to 24x converter module.
-You will also need to drill and tap the block to accept LS1 knock sensors and extend the knock sensor connectors down to each side of the block.
-You will need to extend the cam sensor connector up to the front of the engine. On a '98 harness you should have an exposed 3 prong connector near the EGR pigtail. That is the cam sensor interrim connection. You can extend it from there, makes it easier.
-One last thing PCM wise, you can plug up the LS3 MAP sensor port on the side of the intake and then twist open the vacuum port on the back of the manifold and connect your LS1 MAP sensor to their using a length of vacuum hose.
After a tune the LS3 will, if all goes well, run perfect in your '98.
The following users liked this post:
1998 LS3 Z28 (01-30-2023)
Old 12-14-2010, 12:45 PM
  #103
RGSS's Avatar
This post pretty mch summarizes what I was looking for.
I still have another question:
PCM and engine management wise, does the same apply to an LS7 swap? I am using a 2002 Camaro harness and PCM. Is there any diffeence in the coils?
Thanks for any advise.
Old 12-14-2010, 01:51 PM
  #104
ss.slp.ls1's Avatar
I assume it does, you basically need to use LS1 sensors and LS1 reluctors to use the LS1 PCM (1x cam reluctor, 24x crank reluctor, LS1 MAP, LS1 knock sensors, etc). The thing you will have to check is if the LS2/3/7 (or whatever coil packs you intend to use) coil pack connector connects to the LS1 engine harness pigtail. If it does not, then I don't see why You couldn't cut the connector off the coil pack harness and solder and heat shrink the LS1 coil pack harness pigtail in place so that it will plug into the engine harness. Look up diagrams before you cut anything though.
Old 12-14-2010, 08:04 PM
  #105
1961ba427's Avatar
Where do you get the module mentioned above? Sorry for a newb question...I pretty much only haunt the LT1 section, but I do have an 06 LS2 sitting in a crate complete less intake/TB and a pair of L92 heads on the shelf. Intended to go carb'd in something older, but this thread caught my eye.
Old 12-14-2010, 09:08 PM
  #106
RGSS's Avatar
There you go
http://www.lingenfelter.com/mm5/merc...Category_Code=
The link was posted a few pages before this one.
Old 12-14-2010, 09:19 PM
  #107
1961ba427's Avatar
At first thought....I was all excited about that little box. Sounds like a good alternative to pulling down an engine, locating, and swapping parts.....then I thought about what if it goes out and I'm out on the road somewhere? Or if it's discontinued/obsolete? (Can anyone say Delteq "brain"?) I guess I'd be much safer to break the engine down and swap parts so that it stays serviceable, huh?
Old 01-06-2011, 11:38 AM
  #108
ricks02z's Avatar
Does the racetronics ls1-ksrh knock sensors adapter harness for 29.00 come with 2 harness for both sensors are do you order 2? Thanks Rick.
Old 01-06-2011, 08:42 PM
  #109
TransWS6Am's Avatar
it has both, only need to order 1.
Old 01-07-2011, 05:01 PM
  #110
ricks02z's Avatar
Thanks. Rick
Old 01-11-2011, 10:48 AM
  #111
ricks02z's Avatar
Does any vendors have Racetronics part#ls1-ksrk in stock? Or a contact # for Racetronics? Thanks Rick.
Old 01-12-2011, 04:04 PM
  #112
urock NO IROC88's Avatar
Ok I'm going to be purchasing a LS376/480 here in the next few days and what I have gathered here for a swap into my 2001 Trans Am is that I will need...
58x to 24x conversion box $250
Katech MAP adaptor $30
New LS1 highflow waterpump $125 (not necessary but recommended?)
new motor mounts $50
Oil pan gasket and pickup tube o-ring $40
FAST 90mm throttle body $250 used
LS2/LS7 Injector Connector Kit (part No. 8L480080000, $26
Knock sensor extension No. 1RX-LS2-KSRH, $25
and/or what about this?
https://store.gmperformanceparts.com...-19201327--%3E
comes with all of this...
• 19201790 Engine Controler
• 19166573 Engine Harness
• 15865791 Mass Air Flow Meter
• 19166574 Mass Air Flow Meter Mounting Boss
• 10367117 Accelerator Pedal Assembly
• 12581966 Oxygen Sensor (Qty 2 Per Kit)
• 15156588 Oxygen Sensor Mounting Boss (Qty 2 Per Kit)
• 19171935 Instruction Sheet
Old 01-12-2011, 04:18 PM
  #113
TransWS6Am's Avatar
No need for the map adapter, just a map extension, you also need the cam sensor extension, it wasnt on your list.
As far as the converter box goes id do your homework on it, the have failed a few times and then your stuck on the side of the road. Might want to look into getting the 24X reluctor wheel installed in the crank, i would if i were you.
Old 01-12-2011, 04:28 PM
  #114
1961ba427's Avatar
x2 on that....plus what if it doesn't fail for a few years, and by then none are available anywhere?
Old 01-12-2011, 05:38 PM
  #115
well that's why I am looking into that GM LS376/480 controller kit. Comes with ECU, harness, etc. Only downside is drive by wire pedal... but then I wouldn't need to get the car tuned for the new engine. It's $10 this way, $10 that way kind of thing, I'm looking at what is the least amount of headache and what will make the car run fine for however long!
Old 01-12-2011, 05:51 PM
  #116
TransWS6Am's Avatar
your probably looking at a big head ache getting your stock gauges to work with that controller.
Old 01-12-2011, 07:06 PM
  #117
have autometers setup already haha
Old 01-13-2011, 04:10 PM
  #118
TransWS6Am's Avatar
Nice! go for the controller kit than, i would!
Old 01-13-2011, 09:36 PM
  #119
HioSSilver's Avatar
Originally Posted by WS.666
Can someone make a list like this for an LS7 swap into an Fbody?
Or is everything the same?
x2....I just scored a ls7....to replace my ls6
Old 01-13-2011, 09:42 PM
  #120
TransWS6Am's Avatar
LS7 wont work, ill buy it from you though, hows $200 sound?
lol. I kid. I believe the lS7 is going to be nearly the same as the LS3, but your going to need to do something about the crank, unless you plan to run the dry sump in your WS6.
Quick Reply: UPDATED- L92/L76/LS3 Engine Into 99-02 F-Body
