UPDATED- L92/L76/LS3 Engine Into 99-02 F-Body
#127
I'm inferring that one can run LS3 knock sensors on a LS3 motor in a 98 F-body? I already had the LS1 knock sensors tapped into the side of the LS3 block in June 2010 and have been driving it that way since then. I think I've seen photos of the LS3 sensors mounted and it appears they may give more clearance around the side of the block. Can I easily migrate to the LS3 sensor solution? If yes, which part numbers do I need from which vendors?
Thanks!
Thanks!
#129
Foler, that is an open ended question. Does the BMW need the Fbody pan?? If so then you need
http://paceperformance.com/i-5133402...k-engines.html
#130
#131
Maybe I have missed something along the way here but what do you do about the cam itself? Let's say I have a non AFM l92 with VVT. I don't really care about vvt (would keep it or delete it, whichever is cheaper) and I have an ls1 pcm. Are people just running the stock l92/ ls3 cam? VVT cams seem to be $$$.
Am currently debating the Lingenfelter box vs swapping reluctors (have no clue what that would cost).
#132
-Cam Gear Bolts
-12596023 Early LS2 1x Timing cover w/cam sensor-Supposedly later style 4x will work
*12588670 LS2/LS3 Black Timing Chain Tensioner
*2001 and Newer LS1/LS6/LS2/LS3 Standard Volume Oil Pump (The L92 one is High Volume, I don't recommend it with your smaller LS1 oil pan)
-12576407 Early LS2 2x cam sprocket (your timing chain and crank sprocket are the same as the LS2 which is plenty stout enough)
-Cam Kit w/ Compatible valvesprings/retainers.
LS3's do not have the VVT cam phaser or Active Fuel Management yet. They do however use a single bolt cam and timing gear which is 4x. Therefore a cam change is required to make them work with your 1x/24x engine controls. Like late 06 and 07 LS2's they use the 58x reluctor wheel so you will have to pull the crank to change to the LS1 style 24x reluctor.
#137
LQ4/9 is a Gen III motor. You need to use a timing set and cover from a Gen IV motor (LS2, LS3, etc) which has the cam sensor in the front. Also you will want to utilize the timing chain tensioner which, apart from early Gen III blocks, only Gen IV blocks are machined for.
