Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation IV Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-22-2008, 09:07 PM   #1
89Formulaws6's Avatar
Trader Rating: 51
Default ls3 427
so i talked to a guy on camaroz28who has done this, i did a search and didnt find much, im looking for a sponsor to help me who has done this without oil consumption problems, which the guy on camaro z28 said i wont have any problems if i buy the correct pistons.
im also debating on going with a set of ported l92 heads for this motor since ive had such great success with my stock l92's on my 408, hopefully that intake will be comeing out soon.
whats crazy tho is when i did a search i was seeing ls3's putting down close to what most 408 l92 setups are putting down granted some were dyno jets and mine was a mustang dyno so i cant compare mine 100%. is it the long stroke or something and the restrictive intake?
im looking for 550-600rwhp threw a m6, this will be going into a c5 FRC
im not really up on what the best heads are out there incase someone suggest trick flows ect.
so i guess im open to opinions good or bad
89Formulaws6 is offline   Reply With Quote
Old 10-22-2008, 10:10 PM   #2
LS1TECH Sponsor
1999 Chevrolet Camaro
99blancoSS's Avatar
Trader Rating: 110
We've done plenty of these. My builder HKE has a great reputation and is a leader in the development of pistons for correct use. Your goals are very acheivable, the issue with the L92 is the intake at the moment. You can go with a Beck L92 and hit the mark
I'll send you a pm as well. There are a few options to look at.
__________________
MSD 8.5mm Superconductor wires w/ NGK $68 delivered guaranteed for life.
HKE Precision Racing Engines 347-500 cid N/A, N2O, FI applications
AFR, TFS, All Pro, Edelbrock, Dart head cam specials
Ron Davis Racing.. radiators and heat extractors finest in the business
http://www.ccperformanceparts.com/
99blancoSS is offline   Reply With Quote
Old 10-22-2008, 10:14 PM   #3
Trader Rating: 51
cool thanks!
i mean as it is if i spend what 3500 on a trick flow top end with intake vs a l92 top end with a sheet metal intake for like 3k im saving a lil money im just going for cost effective but not skimping out on anything.
just trying to figure things out before the snow hits
Old 10-23-2008, 10:15 AM   #4
LS1Tech Platinum Sponsor
Matt@Texas-Speed's Avatar
Trader Rating: 3
Going L92/Sheet metal will put you well beyond your stated budget of $3500! The last sheet metal intake we purchased for a combo was well into the $2000 range! Those intakes can also have a BIG affect on RPM range of the engine, which can hurt your driveability if that's a concern.
For the average DD, the GM L76/LS3 composite intake will be just fine. We've built plenty of combos with the PRC L92 heads and that intake in your HP goal range! Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
COMP - FAST - PACESETTER - DIAMOND RACING - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - ASP - AND MORE!
Matt@Texas-Speed is offline   Reply With Quote
Old 10-23-2008, 10:19 AM   #5
Trader Rating: 51
driveability def is something i want, it wont be a d/d but if i happend to want to drive it alot when its warm i dont wanna have a hard time. im sure a ported l76 will be just fine for the setup.
ill definitly be giving you guys a call soon t get a idea of things
Old 10-23-2008, 10:29 AM   #6
LS1TECH Sponsor
99blancoSS's Avatar
Trader Rating: 110
Drivalbility is in the tune and cam selection, if your want to hit 550-600 rwhp then its going to need to get more air than a ported L76 can give it. This is the reason for most of the disappointing results with L92 build. They aren't cam'ed properly and have intake issues. We have a L92 408 with Beck sheetmetal going together right now fpor someone wanting an allout setup. It's all depends on what your goals are and your stated goals are ambitious.
The Beck sheetmetal is $2200'ish alone then you need a Tb for it, the heads about $1875 delivered so around $4075'ish, The trickflows and a FAST 92/92 is around $3975 with a 92mmTB. SO the money is close.
__________________
Old 10-23-2008, 10:39 AM   #7
Trader Rating: 51
cool thanks for putting a few things in perspective, not a bad price on everything, ive kinda got the top end down now im gonna need to focus on the bottom end
Old 10-23-2008, 10:55 AM   #8
Trader Rating: 3
I agree, to an extent. But when you bump the powerband of the engine up 500+rpm with that intake, the low-end power and driveability is definitely affected! I know people drive them daily just like some drive high 240º intake duration cams in their 346's...but they are much more tolerant to this stuff than the average user on the site. For my tastes, the LS3 intake is the better choice for the average DD vehicle!
__________________
Old 10-23-2008, 11:06 AM   #9
LS1TECH Sponsor
99blancoSS's Avatar
Trader Rating: 110
true, very true but we all have different SOP meters for what we think is good manors..LOL
__________________
Old 10-23-2008, 11:14 AM   #10
LS1Tech Sponsor
racer7088's Avatar
Trader Rating: 0
Thumbs up
Quote:
Originally Posted by 89Formulaws6 View Post
cool thanks!
I don't think anyone has made 600 RWHP with L92 heads and an L76 manifold but 550 is probably doable. The pistons are what matters. I did these a long time ago and still do them and have never had issues but used my own special pistons that take into account the bore length. Most of the guys doing the 4.100 and up stroke had problems since they did not know what they were doing on the pistons.
I fixed more than a few of these 4.100 and up stroke deals for several vendors with the correct stuff. Most of the piston makers did not even know at one time how short the cylinders actually are on those engines. Ashley Gable just went 9.50 @ 143.3 mph last night with one of these L92 427s they've had a while. With the bigger stroke and things done right you can not run any large power adders on the engine though.
__________________
Erik Koenig
School of Automotive Machinists
HK Racing Engines
racer7088 is offline   Reply With Quote
Old 10-23-2008, 11:21 AM   #11
LS1Tech Sponsor
racer7088's Avatar
Trader Rating: 0
Arrow
Yes I agree the L76 stuff is more in line with a hydraulic roller street engine although it probably may never hit 600 rwhp.
I think 99BlancoSS was seeing the 600 RWHP goal more than anything else. Even the small bore LS7 heads from ETP would be nice with that manifold if they were readily available (I don't think they are though anymore ).
He could also look at the big TFS or AFR heads and a FAST 92 if his goal is really 600 at the wheels.
__________________
Erik Koenig
HK Racing Engines
Old 10-23-2008, 07:59 PM   #12
formula17's Avatar
Trader Rating: 2
Not to jack this thread, but Im putting together one of these engines as we speak. l92 block, callies crank, compstar rods, manley pistons. I had planned on spraying up to a 200 shot. Would you think that is too much? I hear guys say that is fine and will live a long time, just wouldn't mind another opinion. Also what do you think of the manley pistons?
Thanks,
Nick
__________________
93 Formula 02 front end conversion with Superhawk Hood-427CI, CNC'D L92'S+ A 200 Shot, In The Works! Looking for 9'S!!
"When This Baby Hits 88mph, You're Gonna See Some Serious Shit"
formula17 is offline   Reply With Quote
Old 10-23-2008, 09:12 PM   #13
LS1Tech Sponsor
racer7088's Avatar
Trader Rating: 0
Arrow
Quote:
Thanks,
Nick
Nick, I can't comment on whether those pistons are right or wrong for that application since I never use Manley pistons. I have no idea if they have the skirts right for that app or not but I use their valvetrain stuff a lot though and it's very nice. It's an engineering and knowledge problem and not a quality problem.
I use a different rod length and piston and have never had any issues with my bigger stroker stuff in the regular blocks. I have been doing it for 7 years and now a few people are copying what I did. Most of the aftermarket kit's I have seen are wrong though and had issues at least in the recent past on anything over 4.000 stroke.
__________________
Erik Koenig
HK Racing Engines
Old 10-24-2008, 12:14 PM   #14
Trader Rating: 0
I agree, I also had HKE build my 408 and I have now complains. I also have a Beck intake for my L92 and as far as drivebility I haven't had any problems yet and I using a Accufab 105.
LSX-PWR is offline   Reply With Quote
Old 10-25-2008, 10:17 AM   #15
Trader Rating: 6
Send a message via Yahoo to Black FormulaLs1
can you port the LS3 intake to get a better flowing intake on the cheaper side?
__________________
346 Forged bottom end,P&P 241's, Lunati cam, Ram VDS Pkg, Stage 2 TICK PERFORMANCE T56, moser 12 bolt...sooon #'s and 200 shot
old times with just exhaust and Dr's..
12.56 @ 110 - 1.85 60ft
Black FormulaLs1 is offline   Reply With Quote
Old 10-26-2008, 01:57 AM   #16
05JUDGE's Avatar
Trader Rating: 18
I have a LS3 427 stroker from Texas Speed and am just about to 5k miles and have no oil consumption issues at all. I also made 502rwhp through an unlocked A4. Locked it made 536rwhp. You should easily see over 550 on an M6. I am using a STOCK L76 intake and Stock L76 injectors also. I have been very please with the results I have seen so far. I haven't even switched over to synthetic oil yet. You can check out my other mods in my sig.
__________________
2005 GTO Midnight Blue A4 1 of 368
New Setup coming soon!!!
Old Setup:My GTO, Open Headers At Idle, The Dyno, First 1/4 mile with 427, Idle & Rev - Magnaflow, 60-140mph Acceleration
05JUDGE is offline   Reply With Quote
Old 10-26-2008, 10:57 PM   #17
Trader Rating: 1
Thumbs up
Quote:
Erik of HKE is the real pro when it comes to this stuff and that is why I had him build my forged LS6 blower motor b/c he is the best in the business!
__________________
02 Elec Blue Z06, Forged 347 LS6 by Erik Koenig/HKE Racing, 710rwhp/563rwtq (off meth), all work done by Powerhouse Performance tuned by Jim Moran, ECS D1SC ATI SC, TEA Stage II LS6 heads, 224/230, 114+2, .581/.592 cam, Kooks 1 3/4 Headers, 3 inch X-Pipe, B&B Bullet Exhaust, RPM Level 5 Z06 tranny, Mcleod twin disc clutch; 1971 Prostreet Camaro RS, Split Bumper, Pat Musi 555 cid 740HP/700 TQ, N/A on pump gas.
Chicago Crew UnderBoss is online now   Reply With Quote
Old 10-27-2008, 12:27 AM   #18
LS1TECH Sponsor
99blancoSS's Avatar
Trader Rating: 110
Quote:
Couldnt have said it better myself...LOL
This is why I work closely with Erik to produce my engines
Give me a call if someone needs one, I'm easy to get a hold of and a direct link to da man!
__________________
Tags
427, 600, 600hp, build, dyno, engines, hke, hp, intake, ls1tech, ls3, sheet, sheets, ss, stroker
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
