Fast 102MM LSX-R Intake Manifold for L92 heads at SEMA
Well FAST released the 102mm LSX-R intake manifold at the sema show....they have ported for both the l92 and the cathedral port....
There guy at the SEMA booth (who didnt seem to alot on details I was asking about) told me it was good for approx 15-20 horsepower over the L-76 intake.
I had the same experience at the Comp booth. Light on info regarding the new intakes...........
1) It fits L92 heads!!
2) Interchangeable(?) runners bolt in place (modular design).
3) Front facing ttb and low hoodline clearance.
4) Accomodates a 102mm ttb.
5) It fit's L92 heads!!
Dislike:
1) Display runners looked entirely too long for most performance applications. Hopefully shorter runners are going to be available for rpm tuning.
Here's some pics I took:
Lot's of potential FAST! Nice work!
Richard
__________________ Authorized dealer for and products.
West Coast Cylinder Heads
LS1Tech.com sponsor
Visit us at www.proheads.com
15-20 hp over the stock intake? is it 15 or is it 20?
How much over a well ported stock intake?
Could wind up being only 10 hp over a ported stock piece.
Then again you can port the FAST but still, I don't know.
$1000!! we need some answers.
Nice. It looks like MAP relocation will be mandatory. I like the modular runners although the mounting bosses may be a problem if they are shortened more than a couple of inches. That will also make it more difficult to port. I also like the lack of runner protrusion for the fuel rail crossover. Looks like aftermarket fuel rails are also needed. Very interesting, I can't wait to see more. Looks like the vaporware Weiand may be dead in the water.
i just want to know if it will be able to handle 15psi of boost. if it does that ill buy just for the 102mm intake opening. i also hope they keep the top portion clear!!!!!
Dislike:
Richard
My thoughts exactly. I'd really like to see some runners down around 8 inches. The L92/LS3 heads with the right cam make great low and mid range power. I'd like a manifold that will feed the higher RPM better - even for street use.
We sure do need some educated answers. $1000 for a intake with these gains is kind of steep. I bet their quoted HP numbers were with a tune. So add a few hundred dollars more to the price for that gain
