New Aftermarket Aluminum Block on the horizon - LS1TECH
Thread Tools Search this Thread
Old 12-08-2008, 12:43 PM   #1
7 Second Club
Phil99vette's Avatar
Default New Aftermarket Aluminum Block on the horizon
Apparently there is a new Aluminum Block that is coming out. Word is its very beefy in the mains, 6 bolt compatible with LSx or Warhawk heads, and should be able to take some serious abuse.
Phil99vette is offline   Reply With Quote
Old 12-08-2008, 12:44 PM   #2
veee8's Avatar
You have one on order Phill?
veee8 is offline   Reply With Quote
Old 12-08-2008, 12:50 PM   #3
ATVracr's Avatar
Nice.
No plans this year to change the bottomend but I will be next year.
ATVracr is offline   Reply With Quote
Old 12-08-2008, 01:00 PM   #4
WKMCD's Avatar
Any more info?
WKMCD is offline   Reply With Quote
Old 12-08-2008, 01:29 PM   #5
7 Second Club
We're working on getting one right now but I'm not expecting anything.
Old 12-08-2008, 01:37 PM   #6
LS1Tech Sponsor
I am sitting here in Orlando at ATEC. THe first block is in the back of the room. Overheard they should be available March or April. Don't quote me on that.
The block looks good and is not final machined.
It is by Comp/RHS
Robin
Robin L is offline   Reply With Quote
Old 12-08-2008, 02:05 PM   #7
7 Second Club
Robin,
Shawn is down there at the conference also.
Old 12-08-2008, 04:04 PM   #8
Very interesting. Will it be competitive, price wise, against the Warhawk or are we still too far out to know that much detail?
1.8t is offline   Reply With Quote
Old 12-08-2008, 06:27 PM   #9
LS1Tech Sponsor
Quote:
Originally Posted by Phil99vette View Post
Robin,
Well tell him to say hello!
Robin
Old 12-09-2008, 10:42 AM   #10
Is it the same as warhawk or suppose to be better? Any thing different on this block?
Does comp make other blocks or is this there first go?
I just bought my warhawk hope I didn't miss out!!!!
BigRich954RR is offline   Reply With Quote
Old 12-09-2008, 10:49 AM   #11
Does comp/rhs make other blocks or is this there first go?
Old 12-10-2008, 02:26 AM   #12
CompCams block eh???
Did anything ever develop from Dart on their billet blocks?
CalSpeedPerformance is offline   Reply With Quote
Old 12-10-2008, 07:43 AM   #13
LS1Tech Sponsor
The block is un machined so it's hard to know many things.
Brian Reese touched on the block in his presentation yesterday.
What I remember....
Allows a 4.6" Stroke crank with Lunati Steel Rods Yes I said 4.6" Stroke!
They had to move the oil passage and raise the cam. I thought that they said .380 on the cam.
Enough room to use a 60MM Cam
Cylinder Sleeve length same as a LS7 or was that the C5R, oh well they have longer sleeves
Bore max is 4.165"
I heard it will need tie bar lifters (no big deal)
Room for large lifters
Ability to use 1/2" main studs. He does not recomend that but many people think they need that.
I heard the block was/is cast in the UK
That is what I remember, don't hold me to anything
Robin
Old 12-10-2008, 07:59 AM   #14
I wonder if anybody would notice if that block was missing today?
In my best judgement at this time this block will be the best piece on the market for a high hp ls engine,but it will not be a direct swap,there are some special parts required for the piece(raised cam)but none the less,the main are very beefy and the casting is very good quality.Def another good step in insuring these high end ls engines live
Shawn @ VA Speed is offline   Reply With Quote
Old 12-10-2008, 09:19 PM   #15
427
The block has some very nice features like the LS1 cam sensor and knock sensor bosses, now you can run a belt drive without a dist. The main bulkheads looked wide and beefy, but it was an unmachined casting at this point. Sure looks promising for the future builds.
Kurt
427 is offline   Reply With Quote
Old 12-10-2008, 10:21 PM   #16
Quote:
Kurt
Kurt tried to sneak it out under his coat
Old 12-10-2008, 10:39 PM   #17
njc.corp's Avatar
looking at the intakes coming out and now blocks people are going to have a good 2009
was their any mention if this new edelbrock head would fit on their?
njc.corp is offline   Reply With Quote
Old 12-10-2008, 10:40 PM   #18
racer7088's Avatar
So far it looks easily to be the best of the LSx blocks out yet.
racer7088 is offline   Reply With Quote
Old 12-10-2008, 10:45 PM   #19
njc.corp's Avatar
Quote:
have u seen it erik-
anyone got a picture-
Old 12-11-2008, 12:02 AM   #20
racer7088's Avatar
Yeah it was here at AETC of course.
Related Topics
Thread Thread Starter Forum Replies Last Post
5.3 iron block JayzSS Generation IV Internal Engine 2 09-10-2012 11:08 AM
aluminum LSX block? Abdullah Generation IV Internal Engine 20 06-12-2011 09:12 PM
Painting Engine Block jusTAnother Paint & Body Work 2 08-31-2010 08:11 PM
NEW RHS LSX block 3.8redbird Racer's Lounge 6 02-26-2009 04:08 PM
427 Aluminum Block options 427? SlickVert Generation IV Internal Engine 4 05-24-2006 01:25 PM
Tags
409, afte, aftermarket, aluminum, block, ls1, ls7, lsx, market, oil, piston, squiters
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
