New Pickup Tube Girdle for LSX engines from BRP
Old 12-18-2008, 02:28 PM
BRPhotrods's Avatar
Default New Pickup Tube Girdle for LSX engines from BRP
BRP Hot Rods is proud to introduce the oil pan girdle for the 00+ GM oil pickup tubes (Patent Pending). This is designed for any pickup tube that has the tab attached to the tube. It has been tested on LH8, CTS-V, Truck and 00+ F-Body oil pans without any issues. Anyone who has changed the oil pan on a LS engine knows how easy it is to pinch the O-Ring and cause a pressure leak in the motor. All GM oil pumps feature two mounting bolts but only use one in all OEM applications. This simple girdle slides over the pickup tube to allow for a secure seal of the o-ring. Getting a solid seal on the pick up tube ensures adequate oil pressure when initially cranking the LS engine and through the engines life.
Shown is the OEM tab seal being broken with a ball point pin. This simple girdle could save your motors life for only 19.95.
Kit includes the BRP oil girdle with aircraft grade bolts and washers.
Call BRP for more info the first batch will be available by the end of December
www.BRPhotrods.com
770-751-0687
This will not work on a pickup tube that does not have the tab attached
Old 12-18-2008, 04:48 PM
Tainted's Avatar
that is a brilliant idea
Old 12-18-2008, 08:59 PM
Disturbed Bird's Avatar
how much?
Old 12-18-2008, 09:49 PM
JPH
JPH's Avatar
Great idea guys. I never liked the 1 bolt idea anyways.
Old 12-18-2008, 10:17 PM
BigRich954RR's Avatar
Any one know if this would work on a 06 GTO motor oil pan pump set up
Old 12-19-2008, 09:03 AM
BRPhotrods's Avatar
its 19.95
So far this has worked with every pick up tube that I have seen built after 2000, as long as the single bolt tab is attached it will fit. Only the early 97-99 had a slip fit tab that was not welded to the tube and will not work with this set up.
If it does not fit I will do a full refund no questions asked.
Old 12-20-2008, 12:19 PM
405HP_Z06's Avatar
Looks very nice and a great idea. I wish this was out when I did my cam swap
2 ARP 12 point bolts would work wonderfully on this instead of the bolts in the picture. What is the UHL of the new pickup tube bolts?
Old 12-20-2008, 01:10 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Damn, the engine I'm putting in my 93 is from a 98. I'll have to see if the extra pickup tube I have laying around will work. I know this should work with my LS7 dry sump parts.
Old 12-20-2008, 06:39 PM
TopFlite's Avatar
Great product!
Old 12-20-2008, 09:26 PM
regency's Avatar
so this will help alot with the lifter tick on startup??
Old 12-20-2008, 10:07 PM
Troux's Avatar
I'm 200% positive it will. The GTO has the right pickup attachment.
Old 12-22-2008, 10:16 AM
BRPhotrods's Avatar
I have had some request for ARP and Wire locking bolts that I’m looking into after this first batch of 100. The first 100 kits will ship with one piece aircraft with a built in washer.
Bolt info
6mX20
Zinc Hex
Flanged bolts
8.8 grade
Contrast vibration protections in cast iron
I have about 20 that I was just called and told were finished for inspection and today and today is our last in the office till Jan 5 of 09 at but when we come back in these will be ready to ship.
What it does is reduce oil pressure loss by properly sealing the pick up tube and easing the install of the OEM O-ring that is know to pinch and leak down oil pressure.
Old 12-22-2008, 06:04 PM
camarorat's Avatar
anyone having any luck contacting these folks to order one of these?
Old 12-23-2008, 10:10 AM
ss1
ss1's Avatar
I guess we'll have to give them a call after the new year. It looks like an awesome product!
Old 12-27-2008, 09:26 PM
Bo185's Avatar
Whats the retainer on the sump of the LS7 pan it has two bolts?
Old 12-27-2008, 09:41 PM
TJ
TJ's Avatar
got mine in the mail today. looks like a quality piece.
Old 12-27-2008, 11:50 PM
CharlieC's Avatar
Called 'em, ordered mine on Wednesday, first call.
Charlie
Old 12-28-2008, 11:09 AM
ss1
ss1's Avatar
The LS7 has a dry sump oil system. It's different from the rest of the LSx engines.
Old 12-29-2008, 11:46 AM
Bo185's Avatar
I know that!
Is the pick tube one piece with two bolts? Or is there some kind of retainer?
It looks like one piece.
Old 12-29-2008, 12:10 PM
TJ
TJ's Avatar
I know that!
pickup itself is one piece.
oil pan girdle is one piece.
supplied with 8.8 property class bolts with flanged heads.
its even chamfered on one side.
Quick Reply: New Pickup Tube Girdle for LSX engines from BRP
