Stock L92 Piston/Rod Part number
Old 01-30-2009, 08:49 PM
RickClarke23's Avatar
Default Stock L92 Piston/Rod Part number
Does anyone have the Part number for a Single Piston/Rod for a L92/LS3 engine? I just picked up a motor and it had a valve that dropped. No big damage but I would like to replace the piston/Rod just to be safe. Thanks
Old 01-31-2009, 05:26 PM
anyone have any info at all?
Old 01-31-2009, 08:53 PM
cam75w/ls1's Avatar
The GM number for the L92/LS3 con rod is #12617570. The number for the piston on the LS3 is #89017478. The number for the L92 piston is #89017849. You asked for L92/LS3 piston but they're different numbers. Choose the one you need and these come w/ standard bore piston rings as well.
Old 02-01-2009, 01:26 AM
Thanks so much for the info. I needed the L92 Piston
Quick Reply: Stock L92 Piston/Rod Part number
