Thanks You, "Mast Motorsports"!!
To All:
I had the opportunity to Visit Mast Motorsports this last weekend and meet with the guys that design and build these engines. I was very impressed with the facilities and their knowledge in putting the right parts together and getting them tuned to make big power at a real fair price.
Check out their website (Below) and see what kind of engines they offer. I was able to get a very complete LS3 (427 ci.) that makes 600+ hp for $13,000, and this includes just about everything you need to get it running. They Dyno each Engine and give you the Dyno sheet, and they used really high quality parts.
I just bought a Engine for one of my projects and I am fired up. Here are the specs:
http://www.mastmotorsports.com/gascrate.php
LS3, 7.0L (Hot Rod/Muscle Car) 600+ HP/ LIST $12995
With M-90 ECM & Wiring Harness
Displacement 427 Cubic Inches
Compression Ratio 11:1
Bore X Stroke: 4.070 X 4.100
LS3 Aluminum Block
Plateau Honed to 4.070True Surface Deck
Engine Block Debured
Blue Printed Shortblock
Rev. Limit 7000 RPM
Crank: Callies 4.100 Stroked Crankshaft
Rods: Callies Compstar Connecting Rods
Pistons: Custom Mahle Motorsports Pistons
Cam: Mast LS7 Core Custom Hydraulic Cam (SS Cam, Duration @ .050 I/E 236/250, Lift I/E .648"/.648", Lobe Separation 114)
LS3 Hydraulic Roller Lifters
Manley 1 Piece Chrome Molly Pushrods
Heads: LS3/L92 Heads
Intake: GMPP L76/L92 Intake
Valve Springs: PAC 1518 Nitrided Beehive
GM Car Harmonic Damper
ACL Rod and Crank Bearings
ARP Head Bolts
ARP Main Studs
Cometic Head Gaskets
M-90 Calibrated ECM
Main Wiring Harness
Dash Harness
Air Mass Harness
Transmission Harness
EGO Harness
Bosch EGO Sensor
Fuel Pump Harness
Fan Harness
LS3 Intake
GM 90mm DBW Throttle Body
Bosch Deadheaded Fuel Rail
Bosch LS3 Fuel Injectors
Mast 8 Layer Air Filter with IAT Bung
Intake Air Temperature Sensor 560-2218 info
Crankshaft Position Sensor
Camshaft Position Sensor
Oil Pressure Sensor
Oil Temperature Sensor
Engine Coolant Temperature Sensor
Engine Knock Sensors
Manifold Air Pressure Sensor
Ignition Coils
Spark Plugs
Plug Wires
GM Foot Pedal
GM Starter
Car Water Pump
LS3 Oil Pan
GM Oil Filter
Extras: $2400 Total
1st Gen Conversion Kit
Motor Mounts for a F-Body Camaro
Fully Programmable Software Package
F-Body Front Runner Package
Hedders (1 7/8 with 3 Inch Collectors)
AN Fuel System with Inline Pump
These engine packages come with just about everything you need to really get going.
Shaun and Horace were very helpful and knowledgable about their products. I just want to thanks them for their help in assisting me in finding the right power plant for my car. I encourage anyone looking for a new Engine to give these guys a call and see what they can do for you.
Check out the web site and see what you think.
Good luck.
Ty
LS3 Aluminum Block
Rev. Limit 7000 RPM
ARP Head Bolts
ARP Main Studs
M-90 Calibrated ECM
Main Wiring Harness
Dash Harness
Air Mass Harness
EGO Harness
Bosch EGO Sensor
Fuel Pump Harness
Fan Harness
LS3 Intake
Oil Pressure Sensor
Ignition Coils
Spark Plugs
Plug Wires
GM Foot Pedal
GM Starter
Car Water Pump
LS3 Oil Pan
GM Oil Filter
Extras: $2400 Total
Good luck.
Ty
