L92 / LS3 into 4th Gen Camaro - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 03-19-2009, 10:06 AM   #21
Quote:
Originally Posted by 01badz28 View Post
I'm a bit of a stickler for calling a spade a spade - the block and heads are technically an L92, so to me it is an L92. However, I am NOT retaining the VVT so it may be closer to an LS3 (the heads are also using LS3 hollow stem valves) if that is how you differentiate it.
I am retaining the stock f-body wiring harness and using the Lingenfelter triggerbox to have the new engine communicate with the old PCM. AFAIK I should be able to keep the stock gauges with this arrangement.
Brief update: The L92 truck injectors WILL NOT fit into the L76 car intake. The LS1 injectors wouldn't fit either, even with the Katech spacer kit (although my LS1 injectors were pretty much garbage, anyway). I broke down and got a set of 39# injectors from FAST.
Looks like the car will be done (assuming nothing else comes up) in 2-3 weeks.
I'm not trying to be a stickler at all. It was just I usually associate VVT with L92 and so I just wanted to clarify for myself, because I really want to keep the VVT and my stock gauges.
Anyways awesome thread and if I don't use the VVT then I will be doing the same thing so I'm glad someone else is doing it before me
2SLO4ME is offline   Reply With Quote
Old 03-19-2009, 10:38 AM   #22
Gotcha. Honestly, I think there is more potential in keeping the VVT. I'm ditching it mainly because I didn't want to spend the money on a Mast Motorsports setup / or rewiring the car to use an Escalade PCM (which I don't even know will work). Also, I haven't really seen how the VVT functions in competition in terms of reliability, where as the standard cam setup is a known factor.
I'm keeping all the VVT stuff for use later. I may go with a VVT specific cam in the future after its been out for a while and there are some proven setups floating around.
Good luck with your swap!
01badz28 is offline   Reply With Quote
Old 03-19-2009, 08:24 PM   #23
I will be doing the same thing.. VVT should be very promising in the future.
hybred-GTO is offline   Reply With Quote
Old 04-08-2009, 12:30 PM   #24
Don't have anything new to add. The motor is going in this weekend, hope to have it dynotuned on the 18th.
My friend that is putting to together snapped some photos of the blown up LS1, thought I would share:
The 6.2L is mostly put together. Just needs a few odds and ends and its ready to go in:
Old 04-08-2009, 03:59 PM   #25
is that piston in the block sideways ?
Tootall is offline   Reply With Quote
Old 04-08-2009, 04:45 PM   #26
Quote:
Yes it is.
Old 04-08-2009, 08:18 PM   #27
KCS
Moderator
KCS's Avatar
Nice carnage!
KCS is online now   Reply With Quote
Old 04-20-2009, 04:05 PM   #28
00BlackSS's Avatar
Damn! very nice build! and that is some wicked carnage
00BlackSS is offline   Reply With Quote
Old 05-09-2009, 08:43 PM   #29
First start:
http://www.youtube.com/watch?v=Fiwq4vwoWCg
Its obvious in need of a tune, that will probably happen next weekend. All the plug and play seems to work perfectly, factory gauges are still usable.
Old 05-09-2009, 08:56 PM   #30
Sounds great man! I finally just got the last few bit of parts for the engine today so I can put it back together and hopefully be at the tuner next weekend!
Old 05-09-2009, 09:11 PM   #31
davidadavila's Avatar
u can still use that ls1 it just needs a good seafoam and some jb weld
davidadavila is offline   Reply With Quote
Old 05-28-2009, 09:27 AM   #32
Well, here are the results (Mustang Dyno, Intune Chattanooga, Tn).
The shop owner stated that his dyno reads 14% lower than a dyno jet. Figure 430 rwhp / rwtq for dynojet numbers if that figure is accurate.
There is one problem area to be sorted out. The FAST fuel injector harness converters were pretty much junk. Several of them were crimped down on the weather stripping, and this required some quick repairs by Scott at Intune. This caused a bank to bank imbalance (which is why the dyno graph is lean - it was only reading the drivers side bank, the passenger side bank is spot on). I've replaced the FAST adaptors with some Ford Racing connector packs, that should have fixed that.
I'll probably try and get the thing re-dynoed after its broken in (it was a 0 mile crate motor) and I can spring for a ported TB and an underdrive pulley.
Old 05-28-2009, 03:45 PM   #33
SIC LSX's Avatar
sweet get that thing on a dyno jet
SIC LSX is offline   Reply With Quote
Old 06-08-2009, 02:57 PM   #34
Thats pretty much badass. I want to do the same thing on my car. Aside from the engine how much money would all the other odds and ends cost to make it work in a 98 Fbody?
Stephen Griner is offline   Reply With Quote
Old 06-08-2009, 04:28 PM   #35
Quote:
Not including the engine, I'd say I probably spent $500 on various conversion boxes / connector adapters / and wiring extensions.
Overall, it was worth it. The car feels completely different than it did previously. Patrick G did a good job with the cam - its got tons of power below the curve. First gear is superfluous - you can start the thing in second gear and its still very strong off the line. I'd like to see the peak numbers higher, but this car isn't a dyno queen. I think its going to pretty usable in autox to get off the tight corners I have to deal with. First event is this coming Sunday, so I'll get to find out soon enough.
Old 06-08-2009, 04:32 PM   #36
Mike94ZLT1's Avatar
Quote:
Why? To get higher numbers? A dyno is a tuning tool. If you want a piece of paper that says your car makes 900 rwhp, tell your tuner.
Mike94ZLT1 is offline   Reply With Quote
Old 06-08-2009, 04:36 PM   #37
Quote:
Pretty much. All I wanted to see was the torque curve.
Old 06-09-2009, 06:17 AM   #38
LS1 Tech Administrator
Patrick G's Avatar
That is some big mid-range torque. Exactly what you want with an autocross/road race application.
Patrick G is offline   Reply With Quote
Old 06-10-2009, 11:09 PM   #39
Can you provide the part numbers for the LS3 valves?
caleBot is offline   Reply With Quote
Old 06-11-2009, 10:12 AM   #40
Unless the part number has changed its 12569427 for the LS3 hollow stem intake valves. According to my research, the LS3 uses the L92 solid exhaust valves.
Related Topics
Thread Thread Starter Forum Replies Last Post
Fays 2 Watts Link - Another Stranoparts Satisfied Customer 01badz28 Suspension & Brakes 7 11-22-2010 12:25 PM
Got tired of my ugly LSx, Decided to make it a little nicer! Mike94ZLT1 Generation III External Engine 15 04-24-2009 04:20 PM
test fit of 4.8 in my 79 nova 79nova Conversions & Hybrids 6 05-09-2007 11:40 AM
PICS of 91 ls1 s10. m6 cammed 91s10LS1 Conversions & Hybrids 37 04-03-2007 10:37 PM
my lt4 build up. lots of pics jldak318 LT1-LT4 Modifications 16 03-19-2007 08:48 PM
Tags
2000, 62l, asa, build, camaro, fuel, gm, injector, l92, lingenfelter, ls3, ls6, putting, tr220114lsa, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
