cam sensor problem?
Old 03-21-2009, 05:22 PM
rmaher's Avatar
Default cam sensor problem?
2001 trans am ls1 motor in 1968 firebird. I stroked the engine to 383, from the very first start I' ve had a cam sensor problem? Replaced sensor, sensor plug, checked wiring to computer. The car runs good for about 3-4 minutes at cold start up, then won't run past about 2400rpm after that. my tuner recorded a 20 minute ride. It showed a spike(no signal) from cam sensor. He says it might be the computer. any ideas? Thanks
Old 03-21-2009, 06:26 PM
GEARHED's Avatar
You are most likely to get better information in this forum.
Thread moved, good luck!
Old 03-21-2009, 07:24 PM
3fingas's Avatar
Does the sensor wire run directly to the pcm or does it loop to a connector by the egr or r/f head. If you havent already, ensure that 5v and sig wires arent swapped.
Old 03-22-2009, 12:56 PM
pantera_efi's Avatar
Default LS-1 vs LS-2 cam sensor Power/Ground
The Power/Ground wires need to be switched.
Lance
Old 03-22-2009, 11:28 PM
EARTH MOTORS's Avatar
I had a cam from cam motion the ring on the cam was cut wrong it would run ok ,then no start , then run ok ,the timing would be 180 out 1/2 the time , drove me crazy swap cam ran great jim
