L92 Casting numbers?
Old 03-24-2009, 08:51 PM
Tigman's Avatar
Default L92 Casting numbers?
I bought a set of used heads off of this site and when I recieved them they were 2 different casting numbers. Any problems with that?
Mark
Old 03-24-2009, 09:09 PM
cam75w/ls1's Avatar
Should end with 713 or 714. One part # means heads assembled w/ valves and the other w/o valves. This is what I ended up w/ from the GM Performance parts.
8ByGoat's Avatar
What are the casting #'s?
If one is 823 the other will not flow as good.
Old 03-24-2009, 09:12 PM
Tigman's Avatar
Default Casting Numbers!
One is the 823 the other is 0821.
Thanks
Old 03-24-2009, 09:24 PM
8ByGoat's Avatar
Thanks
Measure the exhaust ports and look inside the heads.
I think you will see they may be finished differently.
FWIW 823 is the best casting #. I can't tell you what to do with those but there is a set of 823's on ls1gto.
Quick Reply: L92 Casting numbers?
