MS4 vs Vrx7 PTV
Old 04-01-2009, 01:57 AM
mrlsxss's Avatar
Default MS4 vs Vrx7 PTV
What would be the difference in PTV between the MS4 and the VRX7??
MS4:
239/242, .649/.609
VRX7:
244/248 .612/.598
Which would have more PTV?
Please expalin both intake side and exhaust.
Old 04-01-2009, 04:15 AM
Sharpe's Avatar
I don't really understand piston-to-valve. So...
Old 04-01-2009, 06:38 AM
SweetS10V8's Avatar
Your going to be asked for more information, you didnt put LSA or ICL.
No one will be able to tell you if it will clear or not, you are 100% responcible for checking NO MATTER what anyone says on here ever!
Old 04-01-2009, 06:12 PM
mrlsxss's Avatar
the ms4 is 111 lsa and the vrx7 is 112 lsa
Old 04-02-2009, 10:24 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The MS4 is built to have adequate clearance in LS1 applications with stock cylinder heads. With hundreds & hundreds of those camshafts on the street you can rest assured that there is absolutely no p/v concerns with our MS line of camshafts.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 04-02-2009, 10:26 AM
STEEPSS's Avatar
Also curious. Anyone know how the VRX 7 compares to the Vindicator, or Vindicator II ?
Quick Reply: MS4 vs Vrx7 PTV
