Sealing Rocker Bolts
I've been looking into a major Oil consumption problem that I have and from what me and some people have narrowed it down to it may be the Rocker Bolts leaking Oil into the Cylinder. I didn't know that they had to be sealed, so there is tomorrow's project.
Here is the details on my problem and what I looked at to come to that conclusion..
-All 8 Cylinders are wet with Oil as soon as I shut the car off, I pull the Plugs out and Oil is on the threads and on the Plug. That rules out the Rings since it's wet, if it was the Rings the Chamber would be dry.
-Last set of Rings that came out of the Engine were flawless(I had re-built this ~6k miles ago due to a Spun Bearing when the Oil Pump failed), so this kinda makes me lean away from the Rings aswell.
-Engine has great Compression and runs very nicely and stable.
-Was thinking Valve Seals, but it burns waaaay to much Oil to be them.
-IMO no way possible all 8 Pistons could have bad Rings or all 16 Valve Seals could be bad after ~6k Miles..not all of them at once.
-Burns most of the Oil on the acceleration and the deceleration.
This what I have come to figure out because all 8 Cylinders are doing it, and every other thing checks out. There is no PCV System on the car, I took it off so I could narrow this down.
Anyone have any input?
Sorry if I ramble on with this..I'm just trying to get this piece to stop burning Oil..
Heads are stock L92's BTW..
LS1TECH & Trucks Sponsor
There's no direct hole to the ports on those heads in stock form. Only some CNC ported heads have the intake rocker bolt holes exposed to the runner.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Yea I found that out when I took it apart earlier..I'm still burning Oil. Next step is pulling the Intake and checking the Runners and the top of the Valves. If they are wet then it's the Valve Seals.
It's just wierd that it's all 8 Cylinders wet..
I'm still leaning toward something in the Heads.. I figure if it was Rings that the Chamber would be dry, but that's my knowledge so correct me if I'm wrong.
I had to use teflon thread sealant on my rocker studs when I installed my AI 200cc heads.
I could see blue smoke coming out the exhaust when the car was idling, but there was no smoke when I was driving. When I would stop for more than a few seconds, the smoke would come back. This was caused by the vacuum at idle pulling the oil through the threads on the studs.
After I sealed the rocker studs, I haven't been burning any oil.
^^With your Heads them Threads more than likely protuded into the Runner, with mine they don't. Later today I'm pulling the Intake and checking the Ports and the top of the Valves. If they are covered in Oil then I know it's the Valve Seals or Guides.
I'll update when I find anything out so hopefully we all can use that info to figure out what's up with it..
I have a 90* Elbow on the drivers side Valve Cover where the PCV Valve would have been. On the passengers side I just have the oil cap, I have been looking into making a Breather for that side aswell.
Well I got the Intake off, on every Valve that is closed there is a nice little pool of Oil.
Looks like it's Valve Seals. I don't understand how all 16 could be bad..maybe I installed them wrong or it's a bad batch or something.
Atleast that's easier than Rings.
What springs and valve stem seals are you using?
__________________
Same issue here too, my studs do protrude into the port (TFS heads) but they are seald. I beleive its the PCV system for me as my manifold was covered too.
