L92 stroker not working properly
when you look at the dyno graph you'll see that the horsepower hangs from 5300 to 6600. I've seen other dyno graphs that pull to 6100 and then start to come down. one the first pulls the throttle body was only opening three quarters of the way. once we fixed that it only picked up 10ftlbs of torque, horse power remand identical and again hung from 5300 to 6600.
The motor has
ported L76
L92 west coast cylinder heads
HK engines 418ci
Kooks long tube headers
90mm nick williams
Any help will be appreciated
thanks,
/Users/josedelapaz/Downloads/JOSE_DE_LA_PAZ.bmp
The motor has
ported L76
HK engines 418ci
90mm nick williams
thanks,
cant seem to be able to post the graph
how images and enable links: for this message | always for this sender
(No subject) Print | New Window ***** Diaz to you - Mar 24 More Details Add to: To Do, Calendar JOSE_DE_LA_PAZ.bmp
