is the coolant bybass pipe needed????
Old 04-14-2009, 07:52 PM
MF1274's Avatar
Default is the coolant bybass pipe needed????
Hi I am confused if the coolant bypass pipe on the front of the motor between the 2 heads is needed? I am getting a couple of diff. opinions on it.
the motor is a ls3 427ci. sould i run with the bypass or can i use the plugs like on the back of the motor? please help I do not want to have any problums.
Old 04-14-2009, 09:25 PM
SweetS10V8's Avatar
DO NOT PLUG THEM ALL, dont let there be any confusion, you need to run the crossover.
GM doesnt do it to waist time, materials, and space. Its such a minimal cost part and everyone runs them, why even waist the time to ask the question?
Old 04-15-2009, 01:09 PM
sroach20's Avatar
im using the pipes on the front and rear teed to the radiator.
Old 04-15-2009, 09:09 PM
rsz288's Avatar
What they said ^^^^^ definately!
Old 04-16-2009, 03:21 PM
Project GatTagO's Avatar
Received 1,389 Likes on 878 Posts
I would run both a front and a rear crossover.
Andrew
