LS376/480 won't idle
Old 04-24-2009, 07:03 PM
braggr1's Avatar
Question LS376/480 won't idle
New 2008 LS3 GMPP create engine won't idle. Runs great, just won't always idle. Any thoughts? Am using GMPP harness and ECM.
Old 04-25-2009, 09:41 AM
Haans249's Avatar
Are you getting proper voltage at idle?
Old 04-27-2009, 12:22 AM
bmxer8699's Avatar
No idea what the could be
Old 04-27-2009, 08:19 AM
Haans249's Avatar
Originally Posted by bmxer8699
i have this same problem same motor.. and am using the ls1 computer with a lingenfelter converter box.
Starting the car it idles fine, idle is set at 950 with that hot cam. and still once leaving after first starting the car the idle dips and the i have to fight with it to keep it idling.
You have to work out your throttle follower, desired airflow, spark, and AFR's to get your car to idle off throttle without stalling. If its too rich/lean coming down to idle it'll bog/stall. If your throttle follower decays too quickly or is too small for the larger motor it'll bog/stall etc... Idle tuning can be a real hassle if you don't know what to look for.
Old 11-20-2011, 08:17 PM
LS6Nick's Avatar
I just installed a LS376/480 in my 68 C10 truck with a 4L80e and Speartech controller. When at a stop light, the truck wants to surge forward and feels like it is going to stall. Also, hot starts are like I have a carburator and the thing is really sucking fuel. Any ideas on how to fix it?
Old 11-27-2011, 11:03 AM
Jimbo1367's Avatar
Take it to a good chassis dyno tuner
Old 11-27-2011, 01:20 PM
cam
cam's Avatar
Check for vacuum leaks. Also bump timing in lower RPM if you have swapped cams
Quick Reply: LS376/480 won't idle
