Need to pick sum compression, how much can I shave my AFR heads?
My compression ratio is way too low after switching to my new AFR heads, I got a good deal on 72cc's so I went ahead and got them. How much can I take off from resurfacing to pick up some compression without weakening the deck without making the head too weak for boost? I like to pick up one point in comp.
Is that possible?
Is that possible?
Is that possible?
Is that possible?
hey, havent checked on this thread in a while, thanks for the replies.
Im running forged LS2 with ls6 cam/intake AFR 72cc, 6lbs, daily driver.
Ill mill them down to 66cc, change down to .040 gaskets but I think ill leave it alone for a while since it runs good enough for now, even off boost. Ill go back and redo the exhaust and mill the heads and turn it up to 12-14lbs when funds allow again.
I just does not seem worth it now, for such little gains short of getting new heads
thanks for all the advices!
