What spark plugs for 427/TFS 235 heads?
If it is an N/A motor (which I assume it is), it depends on your dynamic compression ratio (DCR). If it is higher, you'll want to run something with a cooler temperature rating like an NGK BP7EFS. If it's normal compression ratio, the NGK TR-6 will do fine.
This is a useful read: http://www.ngk.de/Spark_plugs.649.0.html
Share your static compression ratio and your cam specs and we can point you in the right direction.
Your DCR is less than 9.3:1 assuming a typical lobe profile. I would start with the TR-6, and if you can't get alot of timing out of them, switch to the cooler BP7EFS. If you plan on running nitrous, then start with the BP7EFS.
