LS7 Intake Manifold, Long EV1 injectors (LS6 ECM) what fuel rail?
Assuming some spacers will be involved if the LS3/LS7 fuel rail is used, but does anyone know how to combine the longer injectors with an LS7 intake manifold? Will any just bolt up without spacers? Which of the stock LS1, LS6, LS2, LS7 fuel rails will work? [Not interested in an aftermarket fuel rail.]
Thanks
Thanks
i use thes for my ls7 intake manifold with EV6 Injectors.
http://www.speedinc.com/catagory.cfm?catagory=Fuel / Cooling#
Why do you want to change to longer injectors? I have to assume your looking for larger injectors?
FAST makes drop in replacements for the short LS7 injector that are 50lb/hr (#30507-8)and 65lb/hr (30657-8). I wouldnt waist any money on spaceers, use the money to make the injectors cheaper!
Long injector = EV1 plug
Short injector = EV6 plug.
I'd rather pay $30 for a spacer kit and a clean install than $100 and have a bunch of 6" pigtail wire adapters in the engine bay.
