Need help building a 427 short block
This engine will be mostly NA but since I have a Direct Port Nitrous System I might as well use it. Here's what I am going to use for a top end.
-C5R Heads
-Beck's sheetmetal intake
-Accufabs 105mm TB
I would like to spin the engine high in order to get the full potential out of the heads. I would also like to have the lightest rotating assembly possible. This motor is going in a road racing car and I would like to keep the comp. 11:5:1. Which parts should I go with? Ti rods, billet crank, custom JE pistions.... I don't really want to go solid roller is it still possible to go with a hyd cam and lifters with Jesels rocker arms for the C5R heads? Oh and I would like to use a LS7 block. ROBIN if you could help me out with some info that would be great. Any info would be great guys thanks.
-C5R Heads
-Accufabs 105mm TB
The shot of nitrous will just be there just in case. You know how they say " Its better to have it and not need it then to not have it and need it" A 200hp shot at the most.
