Comp Cams NEW TRUNION KITS!!
Comp has released a new trunion to replace the faulty GM style
Here's the info http://www.cpgnation.com/forum/comp-...nion-2275.html
I know Harlan does it but these look to be cheaper
JS
JS
Looks like Comp is using a caged bearing design. This is the design that failed on the HS with their first design units. They (HS) have since changed to a full compliment bearing wich results in larger rollers and better load spreading.
Welp maybe you took my post the wrong way. I was pointing out some key differences between them that I have found out thru some research and phone calls to HS. Nowhere near 2600 but still very light indeed compared to most.
