knock sensor questions on ls2 ? and how to plug a oil dipstick hole
Ok first i have a warhawk block Trying to mount the knock sensors from my old ls2 block . They are the two black sensors on both sides of the engine right above oil pan with a bolt going though the middle right ?
The bolt holes are bigger on the warhawk block. Can i drill out the knock sensors so a bigger bolt can go though the middle and hold it to the block ?
oil pan is mounted on block starter and most of the mounts and i now know which oil dipstick hole i need to use. HOW do i plug the extra dipstick hole in block?
I don't think it is advisable to drill the knock sensor?????
Dipstick is solved with this....
http://www.kurturbanperformance.com/...ick-plugs.html
Cool thank you just order the plug. Yea i didnt want to drill the knock sensor but i called around few people said it should be fine so i guess thats what ill do if some one doesnt give a me a reason not to ? OR a better way to mount it
