2007 tbss cam swap ?
Doing a cam swap in a 2007 tbss. Going from the stock single bolt cam core to the aftermarket 3 bolt core. Using the correct 3 bolt cam sprocket and chain dampener from an 06 C6. My question is this. Is the chain supposed to be on the loose side? The stock 07 tensioner takes out the slack but the 06 setup doesn't affect the slack in the chain. Is this normal? I've read a post on here that said it was but was hoping for some more input.
