Spun rod bearing, what now?
Pretty sure i spun a rod bearing at the track, it is tapping and squeaking inside the engine.
What do I do now? It was torquer v3, full boltons, HSW wet 150 kit.
So i think i pretty much need my shortblock rebuilt completely right?
Should i rebuild it with forged internals, should i just forget it and change engines to something else?
I dont have a lot of money to throw at this so lets keep it cheap.
If i rebuild it, i want it to have more horsepower N/A and be able to handle the spray without blowin up like this one.
Any tips to finding a nice ls2, ls3, or other good gen 4 engine to work with? Anyone got a lead on anything in or near SE michigan? Do you guys think my heads and cam are still good enough to reuse?
cheap blocks and stuff never end up cheap. I just bought a new iron 408 complete with double roller chain and lifters for 2200. thought i got a steal, which i did but instead of building my h/c camaro for 3200 i will build a 408 for 7000. then again the 346, good parts, the 408, best parts. i am on a strict budget being that i am 20. my block is just sitting there rusting lol. i would do like novaflash said and just rebuild and forge the stock, cheap and sturdy. you will lose N/a depending on what you buy because of the weight difference in parts. but you can make it spray fat, like me with my 408 at least a 200 shot, i will take mine to a progressive 300.
i went ahead and got the mahlf forged pistons/rods and clevitte 77 bearrings and hellfire rings ...just had a solid rebuilt done..then added ported&polished 241s..now need to get a full on dyno tune..but a forged engine will take more abuse and you can always save for something else...
I tore it apart, heads and pistons seem alright, one of the pistons has no carbon on one edge and is slightly loose. I am pretty sure its the bearing, have to get an engine stand to flip it over.
when it's repaired be sure and run 1 extra quart of oil in it. tbss have a problem with oil getting away from the sump and causing bearings to spin. the pan is the real problem. moroso is making a pan for them with a baffle to stop the oil from running back away from the sump. if you need more info contact billy at rpm (ryans performance machine) in nc or sc. he helped develop the pan and has seen lots of tbss engine failures.
You won't really know what to do until you get the engine out and completely disassembled and determine what the real problem is. Does it have any oil pressure? Usually with a spun bearing your oil pressures drops to nothing.
