Lq9 w/ torquer v3?
Just fine. I assume you're talking about 317 castings? an LS6 intake won't work if it has the truck accessories, but if you swap eveyrthing from your f-body to it, it'll be fine.
Hotrod magazine did intake comparison back 2007 on a 6.0 LQ9 .They compared all the car intakes ,truck intake and FAST 90. The dyno results for the truck vs LS-6 were virtually the same with only a slight gain to the LS-6 across the board in all rpm ranges in both hp tq ratings.
It will fell good... I had LQ9, 243's, Torquer v2 and LS6 Intake. Dude my car felt like a monster also my car is a 6 speed so that helped a little. If I were you I would look for some 243's or mill you 317's down to raise your compression. Trust me you will like the difference and is definetly worth it.
