The LSx 102mm LS7 Intakes Are In Stock @ TSP!!!
Guys we just received a few of the LS7 Fast 102mm intakes here at TSP!! Here's the info & link to order!!
http://www.texas-speed.com/shop/item...=1018&catid=20
Testing on a modified LS7 engine with a Big Mouth 102mm Throttle Body™ produced gains of 31.3 horsepower and 26.6 ft/lbs of torque at the flywheel over the stock intake!!!
Constructed from the same advanced polymer material as the LSX™ 92mm Intake Manifold, the LSXR™ offers a host of benefits over aluminum aftermarket intakes, including lighter weight, increased strength and improved heat dissipating characteristics. While the LSXR™ features a 102mm air inlet that is perfectly suited to the FAST™ Big Mouth 102mm Throttle Body™, it can also be used with stock or aftermarket 90mm or 92mm throttle bodies. Other features include integrated nitrous bungs and perfect bolt-on fitment that allows the use of factory accessories without modification or clearance concerns
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Anyone find a bank offering good rates on second mortgages or home equity loans?
While you're taking pictures, put a GM 12569124 fuel rail on top of it and let's see how it fits.
