ARP Rod bolt specs
Old 07-21-2009, 11:23 PM
StreetSilverado's Avatar
Default ARP Rod bolt specs
I've been searching this for the past two days and can't really find anything. I'm putting a motor together and was wondering the torque specs for ARP rod bolts for stock rods. I was told around 45lbs but was wanting to make 100% sure before I put it all together.
Old 07-22-2009, 04:24 PM
KCS
Moderator
KCS's Avatar
200ft-lbs...
...or call ARP technical support @ 1(800)826-3045 and find out for sure.
Old 07-22-2009, 04:28 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
^ please remember that the interweb does not transmit sarcasm very well...
arp has this listed on thier website as well as in the catalog.
they have 2 diff specs for the bolts
the 8740 is 45
the pro2000 is 40
those are arp specs straight from the book
Old 07-22-2009, 05:03 PM
novaflash2002's Avatar
also can depend if its a after market rod, my arp 2000s requested 45ft-lbs on the rods.
Old 07-22-2009, 05:05 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
From his original post:
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-22-2009, 05:08 PM
thanks buddy
Old 07-22-2009, 05:15 PM
thanks buddy
Anytime, Pal!
__________________
Old 07-22-2009, 07:48 PM
Thanks
the 8740 is 45
the pro2000 is 40
Old 07-22-2009, 08:40 PM
XtraCajunSS's Avatar
Also, remember those specs are with moly-lube and each bolt should be torqued to spec and 3 times. These instructions are normally included in the package with the bolts. Have you opened the package yet?
Shane
Old 07-22-2009, 09:52 PM
Shane
The rod bolts I got came in a small package with no notes or any kind of paper. I did use moly lube and torqued 3 times. Thanks
Old 09-08-2009, 11:53 PM
Otto-813's Avatar
Do they need to be torqued 3 times if you are also using a stretch gauge? Or once they are stretched to spec that's it.
Old 09-09-2009, 12:15 PM
raymond mckinney's Avatar
You dont have to rebalance the bottom end changing the rod bolts?
Old 09-09-2009, 12:27 PM
If you have the proper stretch specs and are able to achieve the proper stretch, torque is irrelevant.
Also, you do not need to re-balance your rotating assembly when changing rod bolts.
Shane
Old 09-09-2009, 04:30 PM
Otto-813's Avatar
Thank you sir!
Quick Reply: ARP Rod bolt specs
