Thread pitch - SCAT crank- flywheel bolts?
anyone else having a problem with this?
ARP "LS1 flywheel bolts" will not thread into the SCAT crank, nor will stock GM LS1 flywheel bolts.
Looks like we need to get bolts with a different thread pitch?
BEFORE you run this motor....MAKE SURE THAT THE THRUST WALL IS THE PROPER SIZE ON THE MAIN JOURNAL!!!!!!!!
This is the reason why my first 427 blew up, if the thrust wall is only 1/4" then the crank needs to be repaired. I'm DEAD serious. The scat crank that I ran also had the "messed" up SBC size flywheel bolts. BEWARE.
does this pic of the crank help?
or this one of the #3 main journal?:
Take it to a good engine builder who knows these motors and get the crank spec'ed out, also mention the thrust wall. He should know what you're talking about. Its the part that contacts the thrust bearing on the outside of the main bearing.
Yep all the SCAT Billets were even like that but these new ones have a normal thrust surface at full height. The bolts in the back are 7/16-20 though instead of the original metric threads.
Haans,
Not that I know of but he can look to see if the thrust is full height like OEM or post a pic of the thrust. Before they only had billets but this has been fixed on all the new ones. I am the one that brought that to their attention like 10 times from being at SAM to even showing them at PRI but they seem to have it all fixed now. Originally they told me I didn't know what I was talking about but I deal with them now and their stuff works great.
i wonder if the shipping date would offer a clue.
i bought the rotating assembly from Scoggin Dickey and it was balanced by them and shipped to me the end of February 2009.
if something was wrong with the crank, do you think Scoggin Dickey would have noticed it when they balanced the rotating assembly?
here's another pic i took during engine assembly.
it "looks" like the thrust surface of the crank is as tall as the thrust surface on the main bearing, so maybe i'm ok?
Yes they ahould be fine. Just another crank besides the different flange bolts.
