LS7 rocker arms
I have the proto-type crower shaft units and used them for 3 years now. U can get them in stainless or now in aluminum (so I am told). I had used crowers like these in extreme off-sets in sbc motors w/ welded/re-shaped intake runners, and have yet to see a failure or have an issue w/ reliability. I would opt for the aluminium units over stainless for the more aggressive Hyd. rollers.
Another thing to consider is that these require machining the rocker bosses on the stock heads, while aftermarket head provide the proper surface and supply u with the proper stands if u choose to run stock-type rockers.
