Low oil pressure? First time starting engine...
So i got my engine fired up for the first time today...It's an '05 LS2 from a vette. Engine oil is 0-30w amsoil.
http://www.youtube.com/watch?v=WVm0JODIpHg
Issue is, oil pressure reads low...25 psi at idle (1300 rpm, cold), and only gets up to about 50 when i take the engine to 4 grand. I didnt run it for longer than the video. Is this acceptable oil pressure or should i be looking for problems somewhere? Autometer phantom gauges if that makes any difference.
general rule of thumb 10-12psi to every 1000rpms.
Id try a heavier oil, I had Castrol Magnatec drop me to under 20psi about 1000klms after oil change. When I dropped it the stuff came out with a consistency like water. Have used edge sport 10-60 and have never had issue since.
Other thing to look at maybe the gauge is off.
GM spec 6psi @ 1000, 18psi @ 2000, 24psi @ 4000.
Many miles on the motor? Let it warm up and see what the pressure is and if it is down in the GM spec area then it may need some 40 to 60 weight to get you some safety margin.
Originally Posted by dwfronk
I dont know how much this wil help but i have heard that some ppl when they put in the pick up tube the o ring gets pinched and causes it to loose some oil psi.
If you're gonna beat on it.... switch to 10-30.
