Valve Spring Removal Tool?
Can someone tell me what is the best valve spring removal tool with the heads on for LS3 heads. I saw that Lingenfelter and Crane have one but I don't now which one would work the best. My engine is in an old GTO so I don't have to worry about the cowl getting in the way. Thanks for your help!
Moderator
I just finished swapping springs and I used Thunder Racing's tool for all except the back passenger side springs. My opinion? It needs to be made out of steel. It's made of aluminum so when I used an extension for the back springs, like the website recommends, the torsional load caused square hole for the ratchet drive to deform and wouldn't hold the ratchet drive. It would probably be fine for an LSx engine that doesn't sit behind the windshield like an F-body does.
I ended up making my own "Tim's Tool" and finished it in about 20 minutes. The "Tim's Tool" design is the best bang for your buck, but the Crane/Speed Inc. one looks like it would be the best period.
**disclaimer** Not bashing Thunder Racing, just trying to give feedback on one of their products.
Guys,
My tool does work on L92 as well as LS7 style heads with the offset. As stated above the tool can be rotated to compress the spring and have had plenty of feedback on the offset heads that it works GREAT.
Thanks,
Tim
Thanks,
Tim
