Trailblazer LS2 differences?
Old 10-09-2009, 06:47 AM
CodeRed30's Avatar
Default Trailblazer LS2 differences?
Is the aluminum LS2 from a Trailblazer SS the same as the GTO LS2? If not what are the differences??
Old 10-09-2009, 02:09 PM
DrkPhx's Avatar
The engine itself (block, heads, cam, rotating assembly, etc) is the same, but it has a different throttle body, intake, oil pan and obviously the accessories.
Old 10-10-2009, 06:15 AM
CodeRed30's Avatar
Stellar. It'd be swapped into a Z, so the intake, oil pan, etc will be swapped anyways. I'm assuming the GTO or C5 6 speed will bolt up without issues?
Old 10-10-2009, 08:40 AM
sabastian458's Avatar
not the c4 6 speed. Those are mounted in the rear and are a transaxle set up. The gto 6 speed is like all other f bodies, mounted to the engine.
Old 10-11-2009, 07:47 AM
CodeRed30's Avatar
So the GTO 6 spd WILL bolt up? Seems like the TBSS motors are alot less than the GTO motors, so that's why I'd like to find out what'll work together so I can find the least expensive solution for a swap.
Thanks for the help!
Old 10-11-2009, 03:50 PM
jw33's Avatar
Yes it will bolt up. I have the same setup..... Don't forget the pilot bearing.
Old 10-11-2009, 04:52 PM
JCattSS's Avatar
As stated above the longblock is the same. The 2006 TBSS has a 24x reluctor wheel and 2007-09 are 58x. I think in some other applications the 2006 had a 58x ??
Old 10-12-2009, 03:29 AM
CodeRed30's Avatar
Outstanding. Thanks for the help guys!
Quick Reply: Trailblazer LS2 differences?
