what # from this 402 combination
hope im in the right cathegorie for this post, i'm putting togheter a ls2 stroker 402 10.6c/r patriote stage 3 heads, 228/230 duration, 585 lift + 1.8 rocker full roller alum. adjustable, ls6 intake,38 inj. pacsetter 1 3/4 headers and off road y into loudmouth exth. 6 speed, stock rear. what maners and hp, tq do you think, i was looking for bottom end torque more than top hp. and do you think my stock fuel pump can handle it. burnt #7 with to mutch nitros in the ls1, now i am off the bottle.
I agree with GTSLO88-430-440hp. Your cam choice is a wimp. A bigger motor will take more cam and idle/drive smoother then a smaller ci motor. The 402ci will give you plenty of low tq by the ci's. Headers should be 1 7/8 Look what allignc5 gained going from a 1 3/4 vs 1 7/8 on a 402ci. you will need a 155 fuel pump to be safe. If you must save money then start with the fuel system and add the headers,Intake,ect later to get what you need. By the way,nothing wrong with the bottle. I have sprayed 250hp with no issues many,many times. The problem i'm sure was YOUR FUEL SYSTEM. Goodluck to ya.
i was looking for a daily driver that had good maners but sounded like it has a cam and bottom end torque, the wife and kids like to go for drives on weekend (me driving) but hates when it sthalls. i know its all about the tune but i only had a crane cam tuner. how will this idle compared to my old ls1 stock with cam 224 duration .585 lift. i know bigger cam but bigger cid
you are really choking this motor. when youre going to big cubes, everything has to go bigger. you arent going to take advantage of those new found cubes with ls6 heads, manifold, small primary headers, and a small cam. far from optimum. you can go well into the 24x/24x range with a fast some good heads (AFR/TFS/PRC) and some 1 7/8 headers and itll drive fine. its all in the combo. im gonna say mot much more than 450-460 out of this one.
You sir have WAY to big of a cam!!!
To the OP, like everyone is saying, you are considering a very very small setup and gonna end up selling yourself very short on potential. Not saying go for the max but you could definately get a dramatic increase over the current and suffer NO driveability issues. At least consider a high 230s to mid 240s Intake and exhaust durations, with at least a .600 lift, and you could go for a 113-114 LSA. Should be fairly easy to tune and very street friendly, with a considerable amount more power.
talked to my engine builder about cam and he sugested 236-242 112 596-612 lift if i wanted to release some power and keep drivability good. i have to make desicion by towmorrow, and once i put my 1.8 rockers= like 648 lift. all i want is for it to sound good and good street maners, for power i have enough,425 or 450 or 475 is good for me, later i will upgrade intake system. any one have experienced 402 with this cam.
