Stock LS2 shortblock RPM/power limit
I'm thinking of building a carbureted LS2 with L92's, big cam, victor jr etc that will be run on motor. What is the safe RPM limit of the bottom end, and what are the weak links? How good is the crank if I changed out the pistons/rods/bearings? Thanks
Who ever told you that the rod bolts are good has no clue about the LS series of engines ... do not listen to any more advise from that person .... it is a well know fact that the rod bolts are the weak link in the rotating assembly .... this is not speculation it is fact and has been for a long time.
