LS2 vs LQ9 Weight Difference???
Old 11-09-2009, 08:04 AM
RENE'S RAGE's Avatar
Default LS2 vs LQ9 Weight Difference???
Thinking about going bigger this winter, just wondering the weight difference between the LS2 and LQ9 bare blocks. I'll be using my Lunati forged crank and rods. So 402 or 408. New to the Gen IV scene. I'm sure I'll have a million questions later on. Thanks George.
Old 11-09-2009, 08:13 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
you will be looking at around 80 pounds difference
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 11-09-2009, 01:35 PM
Thank you,Sir. How far can you bore a LS2 to be on the safe side. What's the biggest cubes can I get with my 4.0 crank and 6.125 rods with the LS2.
Old 11-09-2009, 02:18 PM
I don't like to go past a 402
__________________
Old 11-09-2009, 05:40 PM
Thanks again.
Old 04-22-2014, 12:01 PM
mikesanto70's Avatar
402???????? Did you possibly mean 408, because an LQ9 with a 4" stroke crank is 402, so you did not increase bore size what so ever, making sure everything is round and boring just a weeeeeeee bit to a 408 is dangerous according to you?, maybe not dangerous but not recommended???????? REALLY??????????? Just a little tiny bore such as that is not advisable, please do tell because your obviously more qualified than me to answer that one for sure!! Not trying to be a "dick" , no pun intended!! just curious because this is one build being considered by me!! or stroking a 4.8 or an aluminum L33 to a 383, but awesome flowing head choices that are not super high dollar are limited in the 3.9 bore arena!!!
Old 04-22-2014, 12:06 PM
I know it's an old post, but,
"No journey is too great if one finds what he seeks" (Friedrich Nietzsche)
Old 04-22-2014, 06:22 PM
FLYZNTN's Avatar
The OP asked specifically about the LS2 so I believe that is why SD answered it that way. There are a number of builders that don't like to bore stock sleeves beyond a .010 or .005 cleanup.
Old 04-23-2014, 07:56 AM
Wow! That's an old thread.
I went with a LS3 block.
Old 04-23-2014, 09:25 AM
FLYZNTN's Avatar
Good call.
Old 04-23-2014, 01:57 PM
As noted by another poster already (shoutout to flyzntn), my answer was in regards to an aluminum LS2 block, not the iron 6.0 which can be bored further than the LS2 block.
__________________
Quick Reply: LS2 vs LQ9 Weight Difference???
