LS3 vs LS7 Fuel Rails
i believe they are the same part number, maybe someone will chime in, im pretty certain there are no difference in the two...
not sure how the injectors could be any farther apart, the valves are farther apart, not the actual runner.... plus the engines are all the same size, cant move them any farther away from each other.....
The engines may be the same size but the heads are different. Especially the LS7 heads. Since the ls7 has unique heads from the other ls engines they could have cast the injector ports in a different place than on the ls3 heads for example. Im not sure if they are different or not, but if they are different that would be my thoughts on why
