PAC 1518 springs on LS3 heads with XE-r lobes?
I am thinking about using the PAC 1518 beehive springs on a set of LS3 heads with a 234/238 XE-R lobed cam. Has anyone had problems with this setup? Figure it will be ok due to the light weight intake valves but would like to hear real world experiences.
Thanks
Thanks
It was recommended by several cam guys not to run the 1518's on my 92 heads even with lite weight valves (REV). The XRE cams are ground aggresive, a dual spring would be better. I found this out after buying the 1518's. The LS3 valves still have a lot of mass to control at higher rpms. What kind of lift #s does your cam have? I know Mast Motor sports run bee hives on there cams. You could do it. I would call your cam manuf. for more info.
I'm running the PAC 1521's on my FTI cam
LS1Tech Premium Sponsor
I don't think there would be any problems with the 1518's on this one, so long as you check the installed heights and shim the springs up to about .050"-.060" from coil-bind! Even though the intake valve is "light weight", it's still fairly large and relatively heavy, so you'll want to do it right!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Not familiar with that cam. What are the specs? Feel free to PM me if you'd prefer so we don't clutter the OP's thread
__________________
1 Post
I've tested the pac single on our LS3 engine dyno motor with 620" lift up to 7100rpm using lobes similar to a LSL.
That being said the new PRC valve spring kit is very affordable & uses a spring that's several steps above the platinum/xtreme springs.
For well under $300 you get a complete spring kit with springs, seats seals, and retainers built in the US so you know the install heights will be spot on.....
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
