LS Gen IV engines - detailed specs wanted
Old 12-02-2009, 09:30 PM
DAlgozine's Avatar
Default LS Gen IV engines - detailed specs wanted
Looking for more detailed info on the various specs of the LS engine family. Here's some of what I have
Engine.......Bore..................Stroke ..............Rod
4.8.......3.78" (96mm).......3.27" (83mm)........?
5.3.......3.8 " (96mm)........3.62" (92mm)........?
5.7.......3.9" (99mm)........3.62" (92mm).......6.098
6.0.......4.0" (101mm).......3.62" (92mm).......6.098
Anyone no where to find detailed engine specs on the LS? link?
Looking for rod lengths ?
Piston details, such as wrist pin location, are they all in the same location?
Old 12-02-2009, 10:27 PM
rtr2001ss's Avatar
Here's a Gen III Chart.
Old 12-03-2009, 12:42 PM
DAlgozine's Avatar
Thanks, I found some more info ,as well
4.8.......3.78" (96mm).......3.27" (83mm)........6.276
5.3.......3.8 " (96mm)........3.62" (92mm)........6.098
5.7.......3.9" (99mm).........3.62" (92mm)........6.098
6.0.......4.0" (101mm).......3.62" (92mm)........6.098
http://www.gmhightechperformance.com...ory/index.html
http://forums.popularhotrodding.com/...ext/page2.html
(about halfway down the page)
http://www.enginebuildermag.com/Arti...all_block.aspx
http://forums.hybridz.org/showthread.php?t=87947
Old 12-03-2009, 01:06 PM
Petraszewsky's Avatar
Do you need to know compression ratio too??
Old 12-03-2009, 01:27 PM
DAlgozine's Avatar
Sure, if you have more on the Gen IV engines. Here's what I have so far:
Engine.......Bore......................Stroke ..............Rod ......Compression
LR4 4.8......3.78" (96mm).......3.27" (83mm)........6.276.........9.5
LM7 5.3.....3.8 " (96mm)........3.62" (92mm)........6.098........9.5
LS1 5.7.....3.9" (99mm).........3.62" (92mm)........6.098........10.1
LQ4 6.0.....4.0" (101mm).......3.62" (92mm)........6.098.........9.4
LS2 6.0.....4.0" (101mm).......3.62" (92mm)........6.098........10.9
Old 12-03-2009, 01:46 PM
RPO / Displacement / Bore / Stroke / Block Material / Head Material / Compression
LY2...4.8...96.01 (3.780)...83.00 (3.268)...FE...AL...9.1:1
LH6...5.3... " " ...92.00 (3.622)...AL...AL...9.9:1
LY5...FE...AL
LMG...FE...AL
LC9...AL...AL
LH8...AL...AL
LMF...FE...AL
LS4...AL...AL...10.0:1
LY6...6.0...101.6 (4.000)...92.00 (3.622)...FE...AL...9.6:1
L76...AL...AL...9.6:1 on trucks ....10.4:1 on cars
LFA...AL...AL...10.8:1
L92...6.2...103.25 (4.065)...92.00 (3.622)...AL...AL...10.5:1
LS3...AL...AL...10.7:1
LS7...7.0...104.78 (4.125)...101.6 (4.000)....AL...AL...11.0:1
LSA...6.2...AL...AL...9.0:1
LS9...AL...AL...9.1:1
Old 12-03-2009, 02:20 PM
69LT1Bird's Avatar
Here is a PDF file I found a while ago that has a ton of information.
Obviously some part numbers are now changed, they would be GM parts if the numbers always stayed the same.
File Type: pdf
Old 12-03-2009, 04:09 PM
supermouse4's Avatar
The PDF is a reservoir of information. Thanks for finding it.
Old 12-10-2009, 04:29 PM
396375's Avatar
Great info.
Old 12-11-2009, 10:51 AM
396375's Avatar
Anyone know the total weight of a 6.0 iron block?All I can find is that they are about 70#s heavier then a aluminum block.
Thanks
Old 12-11-2009, 10:58 AM
rtr2001ss's Avatar
Looks like the LH6 5.3L is the same as the L33 for specs. I've got the L33 in my 06 Silverado. Good motor but 3.42 rear end ratio makes the truck a pig.
Old 12-12-2009, 11:35 AM
396375's Avatar
I found out the iron block weighs 180 #s.
Quick Reply: LS Gen IV engines - detailed specs wanted
